How often do you have to replace hoses?
/ How often do you have to replace hoses? #1
Highridge
Southeast, MA
Power-Trac 1430 and Craftsman DGT6000
I was looking at some of the pics on MR's web site and there are a lot of hydraulic hoses in that "center tunnel". Has anyone ever had to replace a blown hose in a hard to reach area? How often do they go?
/ How often do you have to replace hoses? #2
Lost 1 in 3 years on 1845
/ How often do you have to replace hoses? #3
I have had mine for 5 years now and have never replaced a hose.
/ How often do you have to replace hoses? #4
Lost 2 steering cylinder hoses in three years and replaced the other two when the second one went on 1845. Not counting the other 38 replaced hoses! /forums/images/graemlins/tongue.gif
Sedgewood
/ How often do you have to replace hoses? #5
The center tunnel looks pretty easy to snake stuff through. So does the front area between the operator's station and the FEL arms. I think the hardest part would be in the engine compartment. As far as life of hoses go... lots of factors. Heat buildup, sunlight, solvents, dirt, abrasions, movement, etc.. all contribute to the life of the hose. I have a late 70's International that still has lots of old hoses on it. They were in bad shape when I bought it 15 years ago and are still in bad shape. But none of them ever blew in the many hours I put on it. With that said, if I ever repair the tractor, I will be replacing all the hoses.
Thanks for the replies.
That's good to know that they don't go that often. I've got a place right down the street that makes hoses and fitings.
And I've got a great Authorzied Deutz dealer too. That 1430 is looking better than ever. /forums/images/graemlins/grin.gif
/ How often do you have to replace hoses? #7
I have blown a couple of hoses in the engine compartment of my 2445 that took me hours to reconnect. I was on a hill in a clients backyard when it went and since it was one of the main wheel motor hoses, I could not move it up or down the hill. I had to get it fixed right away since it was needed elsewhere and rain was on the way. This made it more difficult since I had to work around a hot engine and hydraulic fluid! /forums/images/graemlins/shocked.gif /forums/images/graemlins/mad.gif Other than that, I have a steering hose that needs to be replaced and all of my backhoe hoses have been replaced and uptgraded to heavier hose with Kevlar sleeving covering the entire length of them. Little fixes and upgrades can really save you time and money down the road! /forums/images/graemlins/wink.gif
/ How often do you have to replace hoses? #8
In the commercial use about every two years but only the most stressed once. If you do what Blackwell indicated, select the better hydraulic hose quality, the second time around ... it is just a few $ more and adds a good year of use.
/ How often do you have to replace hoses? #9
Correct me if I am wrong but i think Power-Trac says every 1000 Hrs.
/ How often do you have to replace hoses? #10
Preventive maintenance is great, but if it isn't broke, don't fix it.
/ How often do you have to replace hoses? #11
I agree with that philosophy, my wife wanted me to change out water heaters just because ours was getting old but I wouldn't., thats been several years back and the water heater is still working today.
/ How often do you have to replace hoses? #12
just 'cause it's getting old!! Yikes...I guess I better start lying about my age! /forums/images/graemlins/shocked.gif
/ How often do you have to replace hoses? #13
I have 400 hours on my 422. It is about 4 years old. I replaced one hose. It broke when I dropped something sharp and heavy on it. The other hoses look dirty, but in good conditon.
Bob Rip
/ How often do you have to replace hoses? #14
30 hours on my PT425 and I've already replaced one hose. Only thing is it was the flex hose on my grease gun. I laid the gun down momentarily on the rear tire and the hose flopped onto the muffler. Like an idiot I forgot the machine had just been run so I had instant rubbery goo on the muffler. However, a couple of hours of running later and the muffler was clean as new - kind of like a self-cleaning oven.
/ How often do you have to replace hoses? #15
I am just glad that you have learned how to use a grease gun. Do you also spray lube the joints? This is very important.
Bob Rip
/ How often do you have to replace hoses? #16
Sorry but i guess you are right ... i haven't read that part in a while. My most stressed hoses did not last 1000 hrs.
UNVERFERTH PERFECTA II 18' FIELD CULTIVATOR (A63291)
UNVERFERTH...
2017 Ford Explorer AWD SUV (A61569)
2017 Ford Explorer...
2006 Mack CV713 Flatbed Truck (A62679)
2006 Mack CV713...
2007 John Deere 1790 Planter (A63111)
2007 John Deere...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A61572)
2025 Kivel 48in...
Deutz D 2011 L03 Engine, 3-Cylinder Diesel (A63689)
Deutz D 2011 L03...
