How Often Do You Grease?
   / How Often Do You Grease? #11
</font><font color="blue" class="small">( And I greased mine after each use. I honestly don't know whether it makes any difference, )</font>
I don't think it matters either. I do it before because it is nice and cool in the morning, and after cutting 30 acres I'm done in the heat of the day -- I just want to get a nice cool shower. Greasing at that point is not on my mind. /forums/images/graemlins/cool.gif
   / How Often Do You Grease? #12
Anyone know anything about "Green grease"? Saw it on the Speed Channel where they were talking about how good it was.
   / How Often Do You Grease? #13
I follow the manual's 50 hour (IIRC) recommendation except for the FEL. That's all loose pin construction, so you can't over grease. Grease is the only thing that keeps those pins clean. The worst you can do is make a mess. In wet weather or when plowing snow, I grease after every use. For normal FEL work, maybe every two or three uses.
The pneumatic grease gun makes it a lot easier.
   / How Often Do You Grease? #14
I've never seen "Green Grease". I use Schaeffers Moly Ultra 800 EP.
   / How Often Do You Grease? #15
The only green grease I know of is JD corn head grease.
   / How Often Do You Grease? #16
JD has somthing called polystera?? (sp??) that's sorta a green/black. Works good for me so far... The lady at the dealer recommended it over a Lithium I had in my hand...
Others that work good are Lucas red n tacky and mystick which is a blond color. I forget who makes it.
   / How Often Do You Grease? #17
I found the link to Green Grease . I am in no way connected, just interested to know if anyone has used the stuff and any reason to think it really might be better. Thanks for any informatoin.
   / How Often Do You Grease? #18
I bet the blue JD Heavy Duty waterproof grease would work just as well. I love JD grease seems to be some of the best out there.
   / How Often Do You Grease? #19
I think my manuals call for every 10 hours. I do it once a day if I am working the equipment all day other wise once every 10 hrs.
Leo
BOSS MT 660 Fuel Trailer - 660 Gallon Mobile Diesel Tank, DOT-Approved (A55315)
BOSS MT 660 Fuel...
2017 FREIGHTLINER CACADIA DAY CAB (A57880)
2017 FREIGHTLINER...
2023 PJ Dump Trailer (A55973)
2023 PJ Dump...
2021 ASV RT-120F FORESTRY SKID STEER (A52709)
2021 ASV RT-120F...
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
2007 Pierce Dash Truck (A55973)
2007 Pierce Dash...
