How often do YOU grease your rotary cutter u-joints?
   / How often do YOU grease your rotary cutter u-joints? #11
Just whenever. As long as you do it once in a while.
I have no use for sheilds. I never go near spinning equipment.
   / How often do YOU grease your rotary cutter u-joints? #12
Yikes!
I grease the loader each day that I use it (by use, I mean more than an occasional lift or 5 min of use). The rest of the tractor gets fully greased every full day of use. But reading here, I was under the impression that over-greasing U joints was bad. So I have been greasing the U joints maybe 2 time per season. In terms of hours, that is probably 20-30 hours between greasing.
As the OP mentioned, these things are a pain to grease with the shields on. I leave them on, but have to remove the shaft to grease the joints. I usually grease the slip joint too. Clean and Fluid film everything afterward.
Looks like I should be greasing even more often...
   / How often do YOU grease your rotary cutter u-joints? #13
I mean, if you are professionally running equipment, then yes regular intervals are important. For light use, it's not that important. It's things that NEVER get grease and are totally neglected, abused and dry, that fail.
And, there are things which I almost never grease, like the telescoping zerk on a PTO shaft. It's a bad deployment of grease if you ask me. I would sooner take the thing apart once in a while, clean it and wipe a coating of grease on the shaft by hand. Or caster wheel spindles. Same thing. I would prefer to clean and lube them manually once in a while.
   / How often do YOU grease your rotary cutter u-joints? #14
Every major use they get greased.
   / How often do YOU grease your rotary cutter u-joints? #15
Spring time, try to go thru and grease and check oil on everything. And then, before each major use before I attach it. I don't think I have a shield that has lasted over half a year before falling apart. I don't engage the pto with anyone around the tractor.
   / How often do YOU grease your rotary cutter u-joints? #16
At least every 10 hours on the pto u joints.
Daily isn't a bad idea, we have an unknown number of pto u joints and i can't think of a single pto shaft that doesn't get greased daily if used.
Same here but the sliding halves, every year.
   / How often do YOU grease your rotary cutter u-joints? #17
my eight acres take about 10 hours now.
So every ten hours or so.
It seems these U-joints do not have the automotive cups that seal real well.
When I apply grease it will take a few pumps before they ooze through the cups.....Hm...wonder where'd it go......???...lol.....
   / How often do YOU grease your rotary cutter u-joints? #18
Look at the inside of your PTO shields, it's there in globs.:laughing:
   / How often do YOU grease your rotary cutter u-joints? #19
A little bit not much.
Small flat tip screwdriver release tabs, pull them back.
use shop towels in the U-joint area and wipe up afterwards. So just the little that slings out.
However, the older I get may be the lazier I'll get....lol...:D
   / How often do YOU grease your rotary cutter u-joints? #20
Every once in a while. Easiest is when taking it off or putting it on when you can bend the Ujoints about 90 degrees.
Think once they've been greased, they'll stay greased for a long time as everything's pretty much sealed up in there. Main thing is to get some grease on fairly new ones in case they weren't greased well when built.
Ralph
1990 MACK RD688S (A58214)
1990 MACK RD688S...
X-CEL GOOSENECK TRAILER (A54756)
X-CEL GOOSENECK...
Hydraulic spike driver (A56435)
Hydraulic spike...
2014 Chevrolet Silverado 4x4 Crew Cab Pickup Truck (A56858)
2014 Chevrolet...
2010 International 4300 2,000 Gallon Water Truck (A55973)
2010 International...
2005 INTERNATIONAL 9400I MID-ROOF SLEEPER (A58214)
2005 INTERNATIONAL...
