How often do you check your zerks (aka grease nipples)
   / How often do you check your zerks (aka grease nipples) #13
I've had a couple loose on my tractor since I got it new 2 yrs ago. Angled ones on the loader. If I tightened them snug, they wouldn't be at the right angle to get the grease gun on.
   / How often do you check your zerks (aka grease nipples) #14
Am I odd man out? In decades and many tractors I have had only one loose grease zerk? I had no idea this was so common. Suppose it's newer manufacturing techniques? One zerk that I did try to tighten turned out to be a pressed in fitting on an early Kubota loader and it caused me a lot of grief to replace.
   / How often do you check your zerks (aka grease nipples) #15
I've run 6 tractors for over 52 years now and have never had a zerk come loose. Surprising since they are the most lubricated part on a tractor! :)
   / How often do you check your zerks (aka grease nipples) #16
I've had a few loose or loosen, maybe they were never tight enough to begin with. I just used an ez-out on one the other day that was snapped off on the backhoe stabilizer. Probably a rock got to it. It's shielded put points to the ground and is fairly low.
Until yesterday, I would have said the same thing. I looked even closer today and found one missing zerk in a non critical location (pivot for BH pad). That was an unprotected zerk though and might have just been knocked off.
I do wonder if there is something about the way I remove the grease nipple after pumping into the zerk that might be loosening them over time. I switch between a rigid nozzle with manual lever style and a Lincoln battery powered gun with flexible hose. i wonder if I am unconsciously twisting the nipple off counterclockwise after pumping. After seven years that might unscrew a zerk.
   / How often do you check your zerks (aka grease nipples) #18
Ed, I know it is a lot of money, but trust me get a LockNLube coupler for your grease gun and live a longer life. No rotating the coupler, no pulling, no unscrewing the coupler to loosen it, just a joyful greasing experience. You will need an adaptor ( I made one) for those two zerks on the pedal shafts as the lock n lube is too long to get in there easily, either that or trade out those zerks for right angle zerks like they should have been in the first place. I resisted for a long time but the guys kept on saying how wonderful this thing is, and you know what? They were right.
Amazon.com: LockNLube Grease Gun Coupler - Zerk Grease Coupler Fitting Tip - Easy Lock-on, Clip-off - Stays on - Grease goes in, not on the machine - FREE Shipping & 30 day money back trial plus $3 for return shipping.!: Automotive
http://www.tractorbynet.com/forums/...ssory-your-lock-n-lube.html?highlight=coupler
   / How often do you check your zerks (aka grease nipples) #19
Funny I came across this post, I had a couple loose zerks on my Woods BH that I finally got around to tightening today so I checked them all and found about a half dozen loose as well. Maybe its the way I take my grease gun off too? Or its the Woods BH... The one's on my loader seem to be fine. Worth a check though.
Ed, I know it is a lot of money, but trust me get a LockNLube coupler for your grease gun and live a longer life. No rotating the coupler, no pulling, no unscrewing the coupler to loosen it, just a joyful greasing experience. You will need an adaptor ( I made one) for those two zerks on the pedal shafts as the lock n lube is too long to get in there easily, either that or trade out those zerks for right angle zerks like they should have been in the first place. I resisted for a long time but the guys kept on saying how wonderful this thing is, and you know what? They were right. Amazon.com: LockNLube Grease Gun Coupler - Zerk Grease Coupler Fitting Tip - Easy Lock-on, Clip-off - Stays on - Grease goes in, not on the machine - FREE Shipping & 30 day money back trial plus $3 for return shipping.!: Automotive http://www.tractorbynet.com/forums/owning-operating/318651-accessory-your-lock-n-lube.html?highlight=coupler
Thanks for the recommendation. I'll order one today. The things I hate most about greasing are seeing grease regurgitate from a poor zerk connection and then fighting to get the tip off the zerk. Sounds like this is the device for me. I'm gonna treat myself to a new Lincoln lever gun too as I'm also fed up with my HF cheapy.
2017 BX2680 Sub Compact Utility Tractor (A57024)
2017 BX2680 Sub...
2015 Ford Explorer AWD SUV (A55853)
2015 Ford Explorer...
Duetz Power Unit (A50120)
Duetz Power Unit...
2011 26PS PROWLER 5TH WHEEL RV (A52472)
2011 26PS PROWLER...
2023 KOMATSU PC55MR-5 EXCAVATOR (A52707)
2023 KOMATSU...
25 DUAL AXLE GOOSENECK TRAILER (A58214)
25 DUAL AXLE...
