How often do replace your surge protectors?
   / How often do replace your surge protectors? #1
DrRod
Platinum Member
Ellicott City, MD - Farm in Orbisonia PA (south ce
John Deere 4110
We have fairly dirty electricity at our cabin. Last week the power and/or internet were out several times. Late in the week my computer refused to come on at all. Could be any number of causes [not worth the money to find out] but being fried electrically is a possibility. A tech support guy said it wouldn't hurt to replace my old [10 years] power strip/surge protector. Two people at Micro Center [a really good store] independently said they replace theirs annually.
Do any of you do this or have an opinion?
   / How often do replace your surge protectors? #2
I would guess that the electricity is a lot "cleaner" here. The TV/stereo are on a power strip/surge protector that is going on nine years and still functions correctly. My computer is on an APC brand UPS and it gets replaced about every 5-6 years because a new unit is usually the same cost as a replacement battery.
I would say that if you truthfully need to replace your power strip/surge protector annually - then I would look to something with a lot more "staying power".
You need something that will trip and reset not "blow" once and provide no further protection.
   / How often do replace your surge protectors? #4
Surge protectors are rated in joules, that rating is a cumulative figure. It will take that amount of joules in surges once, or over time. There is an indicator light on them that is supposed to indicate when it is no longer working. That does not always work, even with the really pricey ones. There are some really good test results out there on them. Even the ones that have fault indication that does work it does not work all the time.
Most modern household electronics of any decent quality will have some surge protection built in. It is the #1 cause of power supply failure. To protect the protected power supply use a surge protector. They are way cheaper than buying a new power supply for your LED TV and way way cheaper than paying someone to put a power supply in your LED TV.
Another option is using decent UPS systems as the good ones have surge protection built in and they are power conditioners by nature of their function. You can get some really good ones these days for what I consider to be a decent price. I have them on my main PC and on the living room entertainment system. Which is several computers and a nice TV.
So, how often? It really depends on how many surges/micro surges they take.
I replace all of mine every 3 years, and sometimes on the pricey stuff after storms that have close strikes. I often will take the old ones out to the garage to use as power strips until they finally give up the ghost.
   / How often do replace your surge protectors? #5
Your problem might be voltage variation (spikes and lows) into your systems which can fry or cook systems without ever activating a surge protector. This causes software problems as well. You also need surge protection on your phone line which are notorious for spikes.. After we learned about all these problems caused by power variation from our IT buddies some years ago, we've since ran power conditioner/battery-backup/phone line protection for all our computers. Since then, we've had far less software and hardware grief. In fact close to none. Many battery backups do note have power conditioning.
Hope that helps.
   / How often do replace your surge protectors? #6
I gave up on protector strips. Most are not worth the money you pay. The varistors (surge protectors) are way too small in them to protect much of anything. Your best bet is to buy a good UPS (battery backup), like a good APC. They do a much better job of protection and give you some additional time to shut your PC down if the power goes out.
paul
   / How often do replace your surge protectors? #7
I don't replace our surge protectors but we just are using them as power strips for the most part. They should be replaced though since they do have a finite ability to protect devices.
We do have quite a few UPS units we have acquire over the years. Ironically, with with our switch over to laptops we don't use the UPSes for the systems but we do have our network modems, routers and main TV on UPS to protect the devices and keep everything up when we have a power blib. I do need to go buy a replacement battery for a UPS and put in in use on another TV....
I have been buying UPS replacement batteries from one of the battery stores.
Later,
Dan
   / How often do replace your surge protectors? #8
i havent replaced any of mine.. but i do take the oldest ones and put it in the garage for xmas lights and power tools for outside work. the newer ones stays inside but .. i gotta admit i havent thought about them for last ummmm errr 10 years. SO that being said might be time to revisit all of my strips
   / How often do replace your surge protectors? #9
I don't use surge protectors (SPs) on anything but cheap bedside radios and the phone land-lines. All other electronic equipment get UPS devices. If the surge protector is working, it's probably good for one event. After that it's just a power strip. And most of the cheap SPs don't let you know reliably when they've made the conversion.
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
Memo 98 Loader with Brackets (A50514)
Memo 98 Loader...
2018 Toro Sand Pro Bunker Rake with Edger Broom (A49461)
2018 Toro Sand Pro...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2008 FORD F-750XL SUPER DUTY ASPHALT DISTRIBUTOR T (A51243)
2008 FORD F-750XL...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
