How noisy is your kubota snowblower?
   / How noisy is your kubota snowblower? #1
hazmat
Elite Member
West Newbury, MA & Harrison, ME
Kubota L5460HSTC
Well I got the chain fixed. Worked her for about 15minutes last night. Man does this thing throw snow.
Anyway - it seems kind of noisy. Kind of makes a Wuhwuhwuh sound. Just wondering if it's normal. Wife said it sounded "sick".
My 3pt blower was very quite except for the air moving. Of course, it was direct drive vs. the chain on the B2782.
   / How noisy is your kubota snowblower? #2
I have a front blower on my L3010HST and I wouldn't exactly call the blower quiet but it doesn't sound sick either. I think definitely sounds mechanical and a little "clanky" when it isn't blowing snow. It seems to be smoother when I'm actually blowing snow.
Good Luck,
Kevin
It isn't clanky. Just the wuhwuh sound. As far as loudness - a bit quiter than the MMM is.
   / How noisy is your kubota snowblower? #4
Hazmat,
I had the same complaint with my BX2750. The first time I used it I called the dealer and told them something was wrong because my blower was howling. They said that is the sound it is supposed to make. I think they were right. Everything turned smoothly and without binding. And after three or four years of use it worked (and sounded) just like it did when new.
smfcpacfp said:
Mine seems pretty quiet, but I am in a cab. It is much quieter than my old one.
How noisy is it if you open the door to the cab? I know you're risking frostbite & getting you hot chocolate cold and all...:rolleyes: :)
I should shoot a video so y'all can hear the wuhwuh howling.
   / How noisy is your kubota snowblower? #8
You're right, it is quite a bit louder outside, so another advantage of the cab - quieter.
   / How noisy is your kubota snowblower? #9
Sounds like the chain is too tight. When the blower is spinning the only thing that's going slow enough to make a wuhwuhwuh sound is the chain drive and auger. With the unit lifted up and pto disconnected, roll the auger by hand and check that the chain and sprockets are in good shape and the chain fits and is not too tight. A little play at the idler is better than none. Also check that the auger bearings are smooth rolling. If there is are broken or missing rollers, it will make a wuhwuhwuh noise and once in while rollers might get wedged and try to stop the auger, snapping the chain. I don't think the wuhwuhwuh is normal - it's telling you something is unhappy and may not put up with it forever. As always, prompt cheerful refund if info is bogus. Dick B
hmm - I'll have to try loosening the chain up. the auger & fan make almost zero noise - I happend to spin them when the first chain broke.
2012 DRAGON 150BBL ALUMINUM VACUUM TANKER TRAILER (A52472)
2012 DRAGON 150BBL...
John Deere 6100D (A50120)
John Deere 6100D...
2020 John Deere 160G Excavator (A47384)
2020 John Deere...
2012 MACK ELITE LEU613 GARBAGE TRUCK (A51243)
2012 MACK ELITE...
UNUSED AGT YSRT14 STAND ON SKID STEER (A51243)
UNUSED AGT YSRT14...
Suzuki King Quad ATV (A50515)
Suzuki King Quad...
