How much will my power lift pick up
   / How much will my power lift pick up #1
Hughlofting
John Deere 2355,820 (3 cylinder), 2150, Farmall a, Allas Chalmers G,
I have a 48 b with power lift not power troll I have a horse arena rake that weighs 800 lbs will my b pick it up? With the power lift?
   / How much will my power lift pick up #2
I used to pickup a 6ft flail mower with a power lift on a 47 A. I am not sure what it weighed but they are not light and it didn't have a problem lifting it. You do have to watch as it drops fast when you let it down. They were designed for cultivators and you wanted a fast drop after turning at the end row. It is either up or down. I don't believe you have the control you have with the Power-Trol.
If you can find a Power-Trol it isn't too bad a job changing it out. I have had mine on JD 50 off changing a seal in the lift cylinder. You do have to take off the rear end plate so you do need a motor lift.
Yeah I am going to keep an eye out for one thanks
2014 Ford F-250 Service Truck (A50323)
2014 Ford F-250...
Ford Pickup NR (A50323)
Ford Pickup NR...
Case IH Farmall 75C (A52349)
Case IH Farmall...
2014 Chevrolet Tahoe SUV (A50324)
2014 Chevrolet...
2016 Ford Transit 250 Cargo Van (A50323)
2016 Ford Transit...
