OP
roger_scotty
Without having measured the actual weight, my impression is that most tractors will lift about the same amount in the loader as the 3pt.
As far as a full-length frame goes, I prefer them. But certainly a reasonable alternative to a full frame would be to not abuse the loader like I do do through rocks and roots. I commonly jam the loader teeth into a disintegrating granite rock face, gun the engine, and work the hydraulics until the frame creaks because that is the only way to dig into a hillside out here. But I never "charge" into a pile at any speed higher than low/low. So far, no problems.
My belief is that any loader mounting can is not hurt by any amount of weight that the loader can lift as long as the lift is kept low, the bolts are kept tight, and the speeds are low too. If weight were the only aspect of loader use then I would never worry about the type of loader frame. It is when I'm using the corner of the loader to pry a rock out of the hillside or to pull a stump that the loader really stresses the tractor and makes me glad that I've got a full length frame. I wouldn't do this kind of work with a tractor without that extra support. But you may have a situation where you don't do that kind of work anyway.
I wouldn't base my tractor decision on the loader support system. It would make more sense to just use whatever you get within reasonable limits. Sure, it is known that loaders can break tractors. It happens, but it is a real rare event and I'm not sure we ever hear the entire story.
