How much UDT does my L4400HST hold?
   / How much UDT does my L4400HST hold? #1
tallyho8
Elite Member
North of the Gulf of America, west of Westwego
Kubota L4400, Kubota ZD326
I just changed the hydraulic oil in my Kubota for the first time. The manual says it hold 10.6 gallons.
I added 7 gallons and looked at the sight glass and it looked empty. I checked it again after I added 8 gallons and then 9 gallons. It still looked empty after I added 10 gallons and 11 gallons so I added 12 gallons and it still looks empty.
There are no leaks and I checked my motor oil to make sure it wasn't going in the crankcase.
I ran it a little and the power steering seems weak and the loader seems like it is going up slower than before. The temperature here is 67 degrees, not cold. I am afraid to run it any longer and I don't know what to do next.
Any ideas?
   / How much UDT does my L4400HST hold? #2
Is there any way to measure what you've drained out?
Mike
It's OK now. :) After it sat for 15 minutes the sight glass filled up. I didn't know it too so long to fill up. I wonder if that is normal? I had to drain out 7 quarts to get it down to the right level.
Now I will go let my engine warm up and give everything a good try again.
   / How much UDT does my L4400HST hold? #4
For my B3030, the owners manual says:
IMPORTANT - Do not operate the tractor immediately after changing the transmission fluid.
I always wondered why they state that. Maybe now I know.
2014 MACK GU713 WATER TRUCK (A51243)
2014 MACK GU713...
2000 John Deere 770CH Articulated Motor Grader (A49461)
2000 John Deere...
2017 Ford F-350 4x4 Crew Cab Flatbed Service Truck (A49461)
2017 Ford F-350...
UNUSED INDUSTRIAS AMERICA F08 - 8' LAND LEVELER (A50459)
UNUSED INDUSTRIAS...
2017 Freightliner Cascadia 125 Single Axle Sleeper Cab Truck Tractor (A50323)
2017 Freightliner...
2019 New Holland Workmaster 95 MFWD Compact Utility Tractor with 632TL Loader - Poultry Special (A51039)
2019 New Holland...
