How much "slip" on your TC hydrostatic?
   / How much "slip" on your TC hydrostatic? #21
Re: How much \"slip\" on your TC hydrostatic?
I have been really surprised more of you east coast and Midwest folks have not complained about the relief valves. I often read about all the snow you guys plow and push while in reverse but no one ever says the tractor stalls out. I guess it is something to learn to live with, that is if you can at least get the tractor up the hill by itself with out it stalling out.
George
   / How much "slip" on your TC hydrostatic? #22
</font><font color="blue" class="small">( I often read about all the snow you guys plow and push while in reverse but no one ever says the tractor stalls out. )</font>
Snow and ice makes for less ground traction - I can spin three tires without even slowing the engine down. If I can't get up the hill, it is because of traction, not the relief valve.
   / How much "slip" on your TC hydrostatic? #23
I haven't ever stalled out my TC24. . . maybe I'm not doing it right? /forums/images/graemlins/wink.gif
   / How much "slip" on your TC hydrostatic? #24
I haven't stalled mine either except the time that I sat the KK onto a mound of dirt.....still not sure why the shear pin didn't shear..... but I have had the relieve valve pop too soon - or at least I thought so. First day I had it I pull down into a ditch on my property to grab a bucket of sand that keeps getting delivered to me and I could back up out of the ditch. Ended up having to hook the truck to it to ease out. Haven't tried it again since I've gotten more experience with the tractor though I need to for a couple of reasons. I need some fill around the garage before I put the top soil down and the ditch needs some cleanin' out.
Update on the "slip" after being checked at the dealers.
During the use of the tractor, I again tested it and could not get the slip, rather the tires would spin in low range and 4WD. Another try later and they would lock up and the slip problem returned. So it seemed to be intermittent. I had already made arrangements to have the dealer pick it up, as he also thought it should not be slipping. They came and tried it out, found no problem, but took it back to the shop anyway to make sure. They couldn't make it slip or find any abnormal behavior and asked me to stop by and show them if I could make it slip. I felt like a little old lady complaining about a noise under the hood /forums/images/graemlins/blush.gif
I was able to make it slip under the same circumstances the dealer had tried earlier in the day, he then jumped on and could also make it slip. He was surprised and sent it inside for some pressure checks.
It tests out at the high range of acceptable limits for pressure, so they made no adjustments, which is OK by me but still doesn't answer the question why it does not always spin the tires under load and good traction. The dealer feels that with loaded tires and chains and 4WD it just gets too much traction and something has to give. With a geared machine, that would be the engine, but I still have to think that since the engine still has power, it should be delivering it to the wheels. I have been stuck twice where I had to push out with the FEL because the wheels would not turn, the traction had them "froze" in the mud. Low range, easy pedal pressure, little pull on the motor. More pressure would eventually stall it, but never moved the wheels. I am learning that if I engage it abrubtly, something usually gives. Although they said you can't really hurt anything by doing that with the hydro, it is not the way I prefer to operate equipment. I think it causes undue stress and also can break that last little bit of critical traction that might get you out.
And so it sounds like it is just a quirk of the HST and I will have to learn to live with it. This in no way is a slam on my dealer! They have been great, patient, and have tried to solve my question. Anyone following the local vs. out-of-state purchase debate elsewhere here on TBN - it's nice to have them down the road when you need them.
Brad
   / How much "slip" on your TC hydrostatic? #26
<font color="blue">I have been stuck twice where I had to push out with the FEL because the wheels would not turn, the traction had them "froze" in the mud. Low range, easy pedal pressure, little pull on the motor. More pressure would eventually stall it, but never moved the wheels. </font>
Brad,
Do you mean that one time you can push the directional pedal down without stalling the engine and the tractor does not move, while at another time you can push the directional pedal down and the tractor will stall out, also without moving? In essentially the same circumstances? This does not sound normal. In both cases the tractor did not move and the wheels did not spin. Why would you get two different reactions?
Now if you meant that both times the engine stalled, because it did not have the power to move the tractor, this may be consistant with the dealer's service people finding your HST pressure relief valve set on the high end of the normal range. Many tractors will pop the PRV before the engine stalls, from what I understand, depending on where their PRVs open I suppose. If yours were on the high end of the range, perhaps the engine starts to bog down before the pressure gets high enough to trip the PRV.
It sounds like you may have erratic operation, and a real, rather than imagined problem. Perhaps the pressure relief valve for some reason trips at different pressures at different times. Sometimes too low (low torque to wheels and engine doesn’t stall) and sometimes too high (not enough engine torque to turn the wheels, and the engine does stall)?
Now your dealer saw the problem you are describing and he thought it was odd enough to have his service guys check the pressure. When they checked it was on the high side of normal. Keep in mind that this really tells one nothing, since normal operation could have returned while the tractor was being moved into the shop, and when things are operating normally, one would expect the pressures to be in the normal range. This is the story of intermittent problems; they can be most frustrating and most difficult to fix. This is decades of experience speaking here.
It will be very hard to diagnose [with any certainty] an intermittent problem until it hangs around long enough for the service people to see it happening while they make their measurements. I doubt your dealer would want to follow the change-one-piece-at-a-time-until-the-problem-goes-away approach.
Personally, I think your tractor should, under the same circumstances, operate the same for you consistently. Its operation should be repeatable.
<font color="blue"> And so it sounds like it is just a quirk of the HST</font>
If it were a quirk of the HST the dealer should have told you that and would have had no reason to send it in for pressure checks right away. From you description of the problem I would not be too quick to accept it as a quirk. My non-blue HST doesn’t seem to act like that.
After reading again what you reported in this thread, my gut is telling me you have an intermittent problem with your tractor. The strongest clue is the dealer being surprised by what he saw, after not being surprised by what he saw earlier in the day (when things were working right).
Call this a guess and take it with a grain of salt, naturally.
</font><font color="blue" class="small">( Do you mean that one time you can push the directional pedal down without stalling the engine and the tractor does not move, while at another time you can push the directional pedal down and the tractor will stall out, also without moving? In essentially the same circumstances? )</font>
No, what I am getting at is if you press the pedal all the way down, you are effectively and progressively advancing the tractor into a higher gear. In other words, going across the lawn in low range with no load, a press of 1/4 of the way down moves the tractor much slower than pressing all the way, giving the infinite gear ratio of the HST. So when I was locked in place, I gave it about 1/4 pedal with no spin and little pull on the motor (lets say the equivalent of 1st gear, low range, on a geared machine). For lack of no other options, when I tried full pedal, or the equivalent of 4th gear, low range, it stalled. Most of the time, 1/4 pedal will walk that thing up the side of wall, but occasionly it locks up under heavy pushing or load and slips. That is what I mean by not getting all the available power from the engine to the wheels. A geared machine would either spin, or stall indicating I have exceeded the power capability of the machine. I also appreciate the purpose of the relief valves so not to rip the guts out it or tear apart the implements. But it should be able to get itself out of a hole without ripping the tires off the rims.
I agree with you that it is intermittent. The dealer has asked be to pay close attention to the circumstances and let him know how it goes. Next time I bury it and it acts up, I'll get the camcorder out. He has not been brushing me off in any way and assured me tonight on my way out the door that if it keeps up, he will get to the bottom of it.
Brad
   / How much "slip" on your TC hydrostatic? #28
I have been digging out our gumbo mud catch basin and am getting a little tired of that relief valve shutting down my reverse movements. I have to do everything going forward otherwise the tractor just sits in place till I raise the box blade. The problem you have described seems to affect both forward and reverse motion. I never have had a relief valve shut me down going forward. The engine does stall out but I can catch it from stalling and maintain forward motion if I work the tractor right. Like I mentioned before I owned 2 TC 24D’s and neither had the problem you have described. I would try to find out how to adjust the valve and let all of us know how it is done but I have a feeling that the adjustment is inside the HST not on the outside like it should be, go figure.
George
   / How much "slip" on your TC hydrostatic? #29
George, I don't think the valves are adjustable. At least I know they are not on my Class III hydrostatic tranny. There is one fixed valve for forward and one fixed valve for reverse. They both relieve at the same pressure (5000 psi on a Class III). I could not find the spec in my Repair Manual, but I'm wondering what the "maintained pressure" is when the valves lift? Do they maintain 5000 psi, or do they drop the pressure to something like 3000 psi? What happens if the valve does not completely reseat? If the valve gets hot from the flow of bypass oil, does it change relief pressure?
See, I have lots of questions to get answered and I just may write a letter to New Holland to try to get them answered. Wish me luck. /forums/images/graemlins/crazy.gif
   / How much "slip" on your TC hydrostatic? #30
Jim you have a bear of a tractor I have a cub, so that being said maybe no, it’s more like your tractor is designed correctly and mine is not. I complained to my dealer and New Holland Rep about the problem and was told that the bypass valve was working correctly and was there to save my sorry butt. But if an accusable adjustment can be made I am first in line. I was also told all my pressures were fine but do not know what the specifications are supposed to be nor what they were measured at. Odd thing about the pressure relief valve opening in reverse is that New Holland and others state that when hauling material in the loader and going up a steep hill do it in reverse rather than forward for safety reasons. Well that is kind of hard to do when you can barley get the tractor own weight up the hill in reverse let alone a bucket full of material. So much for the safety.
George
LOT OF RIDGE ROW TIN (A58374)
LOT OF RIDGE ROW...
2013 TRAVIS BODY & TRAILER ALUMINUM BELLY DUMP TRAILER (A58214)
2013 TRAVIS BODY &...
New/Unused SD Lanch 20x30 All Steel Carport (A57454)
New/Unused SD...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
2008 FORD F-750 SUPER DUTY BUCKET TRUCK (A58214)
2008 FORD F-750...
8' X 42" X 10' PALLET RACKING (A58374)
8' X 42" X 10'...
