How Much PTO HP is needed for an 18" Auger?
   / How Much PTO HP is needed for an 18" Auger? #11
IT will be fine.
You wont be able to help but to go slow. No down pressure.
But the HP is fine. The people saying it isnt must not have drilled many holes
   / How Much PTO HP is needed for an 18" Auger? #12
IT will be fine.
But unless you have down pressure assist more HP doesn't affect the down pressure... I my missing something ?
   / How Much PTO HP is needed for an 18" Auger? #13
I use an 18" auger bit quite frequently to dig holes for shrubs and footers for deck posts using my 4060 in all types of soil including the commonly found red clay in our area. As others have said digging is not taxing on the machine, but clay tends to pull the auger into the ground pretty quickly and it does become "stuck" in the sense that it cannot be lifted. My solution is to go slow and lift the auger frequently with the PTO off until it clears the hole. Turn the PTO back on to clear the auger of dirt and repeat.
I have used my BX 2660 to power the auger on occasion, usually with a 9" bit for fence posts, but I recently used it with the 18" bit to dig a footer because the large tractor would not fit where I needed to go. Frankly I was surprised at how well the tractor handled it and I would not be concerned about doing it again. The soil was a mix of gravel and clay.
I use a Danhauser auger with no down pressure cylinder.
   / How Much PTO HP is needed for an 18" Auger? #14
With our heavy clay soil that you can't drive a metal stake into in the summer, I found that my 10" auger does nothing but spin on the surface. You have to have the area just damp enough that the ground will even allow an auger to work and not become an agitated mud pot. Same with my ditcher. I use a drip line, then let it soak in and dry out enough to be able to do anything with it. I also found that I had to modify the leading cutting edge of the auger to better dig into this nasty ground. Even then, I have a big weight on the auger. My 28hp works fine with the 10" with the above caveats, but you may be pushing it with as big a hole as you're trying in dense ground. And yes, with the clay soil, pull it up VERY often to clear the hole, otherwise it will get stuck.
   / How Much PTO HP is needed for an 18" Auger? #15
Why an 18" hole?
The hp required for a post hole drill varies a lot on the way the auger is built. Soil is so completely different everywhere that all a person can do is relate their own experience.
In clay, a lot depends on moisture and advancing the depth very slowly....sometimes with water.
Unfortunately, an inexpensive auger with large pitch, a simple screw tip, and a single cutting edge won't do much in heavy clay soil regardless of auger size. And an 18" would require a really big heavy tractor and probably in heavy clay a category II 3pt. And even so, that's not the way I'd go.
If you use an better auger with a fine pitch and dual cutting edges with bolt-on carbide teeth - a fairly expensive auger - then your 770 should be able to handle a 9 to 10 inch size in heavy clay if everything is right and you can advance it slow enough....maybe with some water. Not sure about an 18" on a little tractor in any soil. That's pushing things.....
Give it a try and let us know.
rScotty
An 18" auger, don't think it's a good idea on a small tractor like yours unless you start with a smaller auger. I would start with a 8" or 9" auger and then you'll see how hard the clay is. Then the 18"
   / How Much PTO HP is needed for an 18" Auger? #16
Think it will work, the thing I would be concerned with is auger speed and possibly stalling the smaller engine. Usually like to keep the speed way down which means idling the tractors engine. I did a lot of 2' holes with the Ford 3000 and the only problem was occasionally hooking into a strong root. This was using an industrial heavy skid steer bit adopted to fit the Leinbach 3 point PHD
Can't speak for anyone else But, I would definitely try it.
   / How Much PTO HP is needed for an 18" Auger? #17
IT will be fine.
I’ve only used an auger one time that I rented for my skid steer and it made easy work of drilling holes. I don’t know what kind of power the auger motor put out but it can’t be a lot with just standard flow hydraulics. I’m honestly surprised at the number of people saying it won’t work. It very possibly won’t work because the small tractors 3 point hitch isn’t big enough but power wise it would be fine.
   / How Much PTO HP is needed for an 18" Auger? #18
edit:
After re reading your response, I see what you were suggesting was to test the soil toughness with a smaller diameter auger to see how the engine handles it, not pre-drill the holes and then step up the diameter.
   / How Much PTO HP is needed for an 18" Auger? #19
An 18" auger in heavy clay soil will most likely require 80-120 Hp. If you're digging footers, I'd just farm it out to someone with the equipment. They usually have a large truck like a drilling rig.
That’s just completely wrong. An 18” hole is pretty easy work and people do it with mini skid augers every day. I doubt you could even find a 18” auger and gear box rated for 120 hp.
   / How Much PTO HP is needed for an 18" Auger? #20
I don’t have much experience auguring holes but I think it’s better to go for the desired hole the first time. I think the bigger auger would corkscrew itself into the smaller hole without much resistance to slow it down.
2014 FREIGHTLINER  CASCADIA (INOPERABLE) (A58214)
2014 FREIGHTLINER...
LOT: Welding Accessories: (2) Auto Darkening Helmets, Welding Rods, Welding Wire, Magnetic Arrows (A59076)
LOT: Welding...
ST225/75R15 Trailer Tires (A55788)
ST225/75R15...
2001 DODGE RAM 3500 (A58214)
2001 DODGE RAM...
John Deere 12in Channel Tooth Bucket Excavator Attachment (A55973)
John Deere 12in...
2024 Schulte 5026 Batwing Rotary Cutter (A56435)
2024 Schulte 5026...
