How much power do I need?
   / How much power do I need? #1
Qapla
Veteran Member
Gator Country
New Holland TC40D HST 4WD FEL/BH
We have a Farmtrac 360DTC with a FEL and a Backhoe. The main use for this tractor is for these attachments.
The tractor has a 3-point hitch, but we have never fully assembled it. I looks like it requires taking the BH off and some of the bracketing to release a lock that prevents the hitch from operating while the BH is mounted. Then we would have to mount the lower arms and linkage to complete the hitch. All this would have to be removed to put the BH back on.
We came up this idea. :rolleyes: Since we have a FEL, we can drop the bucket/rake (we have a bucket and a rake) and use the FEL to connect a mower. Forming the lift bracket on the mower is no problem. We have plenty of scrap steel and a welder.
The tractor has a set of hydraulic quick-disconnects for powering an additional device. We figured we could mount a hydraulic motor on the mower to power the gearbox. This way we can lift the mower as well as adjust the angle to whatever angle we need.
My question is this: What size/power motor would we need to power a 5 mower? :confused:
   / How much power do I need? #2
You would need high capacity hydraulics to run a mower up front. Most tractors do not have that capability even in the 60-70 hp range as high output hydraulic implements are pretty much limited to skid steers and tractors use the PTO for similar functions. I would imagine you could run a special ($$$) hydraulic pump off the PTO to get the sort of output you'd need. Using the Bobcat Toolcat as an example, you would need about 50hp total.
Lots easier to just take off the BH and put on the 3PT.;)
2012 KENWORTH T800 SLEEPER (A50854)
2012 KENWORTH T800...
2012 IC Corporation PB105 Passenger Bus (A48081)
2012 IC...
2010 Mitsubishi Fuso FE84D 16ft. Box Truck (A48081)
2010 Mitsubishi...
2012 John Deere 7280R MFWD Tractor (A51039)
2012 John Deere...
2006 Mack CV713 Granite Tri-Axle Roll-Off Truck (A48081)
2006 Mack CV713...
1500 Gallon Water / Chemical Tank (A50860)
1500 Gallon Water...
