How much oil pressure?
   / How much oil pressure? #1
MartyH
Yanmar 1500D
I don't think I trust those overheat and low oil pressure lights and would like to go with mechanical gauges. Can someone give me an idea of the oil pressure these little diesels are pumping? How about typical temp? I have a 1500D if that changes anything. Thanks for the input guys.
   / How much oil pressure? #2
I'm not that familiar with the 2-cylinder models as we sell the later model units, but for the 3-cylinders like a YM1802D or similar specs are 245 to 392 Kpa (36 to 57 psi) at 1800rpm with a warm engine. There is an adjustable pressure regulator inboard of the oil filter.
On the cooling system, the temperature sending unit will turn the red light on at 230F. On models with thermostats, 160F is the recommended opening temp, and on models with coolant overflow and water pumps, 13psi is the correct radiator cap pressure.
   / How much oil pressure? #3
Marty,
Check out the gauges I put on my 1700
<A target="_blank" HREF=http://www.tractorbynet.com/forumfiles/49-141396-MVC-005S.JPG>My Gauges</A>
Very nicely done gauges inspector507. I'm guessing oil pressure, oil temp, water temp and ammeter? I'm probably just looking for oil pressure and water temp. Probably oil filled Stewart Warner gauges due to the vibration of the 2 cyl engine.
   / How much oil pressure? #5
Very nice indeed!
Soundguy
   / How much oil pressure? #6
Good guess, but missed on one.
Oil Pressure, Water Temp, Ammeter, and Volt meter
   / How much oil pressure? #7
You are making the rest of us look bad, not having a nice set of gauges like that. They look like they came with the tractor.
   / How much oil pressure? #8
I need to replace the water temp gauge. "Someone" did not put the radiator cap back on tight not long ago.......it overheated before I knew and the temp gauge was pegged. Now the lowest the needle goes is 190. When the tractor warms up it shows about 260 and I know thats not correct. Guess it torqued the spring inside.
2022 LMC H40024 LOT NUMBER 206 (A53084)
2022 LMC H40024...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
1986 Peterbilt 359 Truck, VIN # 1XP9D29X9GD196948 (A51572)
1986 Peterbilt 359...
2023 LMC M30018 LOT NUMBER 207 (A53084)
2023 LMC M30018...
1995 CATERPILLAR 621E (A52472)
1995 CATERPILLAR...
