how much loader drop is acceptable?
   / how much loader drop is acceptable? #21
30 year old loader... Does anyone know of a direct replacement for this valve?
Baileys seems to have some bargain valves lately. Check this one out.....
....Surplus Center....
I like the off-the-shelf hoses with npt fittings with adapters going to the valves as needed.
California, If you would like joystick operation, then look at this valve....Surplus Center....
Thanks Brad and J_J ! This advice of specific valves is greatly appreciated. :thumbsup:
   / how much loader drop is acceptable? #22
MF1652,
The relief valve is on your FEL valve, and 3pt valve, and dumps the fluid when the cyl meet a certain resistance. In order to keep something from breaking, a relief valve is used to relieve the hyd pressure, and this is set at the factory, but can be adjusted.
The sound it makes relieving is like a screech or whine. It is not hard to hear it, like when you fully extend or retract the cyl. When you hear that sound, that will let you know that the hyd system pressure is at least operating up to the set pressure. The relief valve will go off until you remove the resistance to the pressure.
No matter how hard you push the levers after the valve is relieving, you will not do any more work other than what you are currently doing. However, some of those relief valves are adjustable and some of the guys squeeze out a little more power. More pressure equals more force.
   / how much loader drop is acceptable? #23
Roy,
What I was getting to was that if the valve is leaking, with the loader raised, and you removed the PB, and return lose, you should be able to see and collect the fluid from the cyl leaking out the ports.
Yes this would work if the PB line is accessible and there are no other functions that could feed oil into this circuit, like the curl.
Roy
   / how much loader drop is acceptable? #24
Based on the info provided, 99% sure its the seals in the spool valve. The curl function on my Kubota does the same since new, boom doesn't move. Drops faster when warm because the oil is thinner. Neighbours NH curl is fine but the boom leaks down really fast, like a foot per minute with a load on it.
Replacement of o-rings in the spool can solve but is a pain. If the cylinder piston seals are shot, you will tend to get blown hoses when lifting full buckets of stuff as once you pick it up, it will leak around so all the weight is carried by the area of the rod. So you had maybe 10 square inches going up then only 4 holding it. Also, piston leak won't let it drop to the ground empty like stated before as both work ports are closed.
   / how much loader drop is acceptable? #25
What O-rings. On all the Ag type spool valves I have seen the only O-rings in them where to prevent the tank line from leaking externally onto the ground. The load holding function is a combination of spool to bore clearance, spool to casting land overlap, consistency of the casting land edges, roundness of the spool and bore.
Probably the two most common causes of leakage are the edges of casting lands being rounded or irregular from the casting process.
Land width on the casting.
Really good spool valves have mated parts with very tight tolerances.
Most Ag tractors are mass produced and for the most part have a more than acceptable leakage rate. Every so often a bad casting gets through just like any other product.
OP states that this happened after some use so I suspect either his spool is no longer centering 1/64 inch can make them fail or possibly a land on the valve casting chipped.
Roy
   / how much loader drop is acceptable? #28
Never had one apart from an ag app, only air cylinder spools. Dealer told me I could rebuild it if I didn't like the leakage, guess not, maybe he meant try a new spool in the existing body.
   / how much loader drop is acceptable? #29
Roy
Roy, the Prince mono block valves have O-rings on each end of the spool held in place with the caps. In my opinion the OEM O-rings are total junk. I replaced mine with double lipped O-rings and have had zero problems since. These do show oil leakage when they are bad though, at least mine did.
   / how much loader drop is acceptable? #30
There are o-rings on my Case BH valve.
2002 WACKER RD25 ROLLER (A51222)
2002 WACKER RD25...
SHOP MADE  MANIFOLD TRAILER (A50854)
SHOP MADE...
Lift Station Pumps (A49461)
Lift Station Pumps...
2025 JMR 36in Mini Skid Steer Bucket Attachment (A50322)
2025 JMR 36in Mini...
4 1/2 150G DRILL STEM 288 JOINTS (A50854)
4 1/2 150G DRILL...
2012 MACK PINNACLE (INOPERABLE) (A50854)
2012 MACK PINNACLE...
