Pat's Easy Change How much lift does Pat's Easy change add.
   / How much lift does Pat's Easy change add. #1
tbohen
Central Michigan
Kubota BX22
How much lift does Pat\'s Easy change add.
Got a BX22 and bought a Howse Middle buster. It won't mount up because its too tall. I've kicked around getting a Pat's system, but I'm hoping it will give me enough lift to use the middle buster, thereby solving two problems. So anyone else with a BX and a Pat's able to measure how much extra lift they get? Thanks.
   / How much lift does Pat's Easy change add. #2
Re: How much lift does Pat\'s Easy change add.
Pat's Cat 1 extends your lift arms by about three inches. Because the lift arc is extended, lift height is increased proportionately. If you could raise the lift arms to a full 90 degrees, that would would translate to another 3" of height. But since you're not likely to lift much over 45 degrees, I'd say your height gain would be about an inch and a half.
//greg//
   / How much lift does Pat's Easy change add. #3
The simple modification shown in the following thread sure helps a lot too... /forums/images/graemlins/smile.gif
BX 3pt Modification
2015 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2015 Ford F-150...
2018 Chevrolet Impala Premier Sedan (A55853)
2018 Chevrolet...
2018 Ford Explorer AWD SUV (A55853)
2018 Ford Explorer...
2018 Chevrolet Tahoe 4x4 SUV (A55853)
2018 Chevrolet...
2019 PJ TRAILER 32FT GOOSENECK (A58214)
2019 PJ TRAILER...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
