how much is too much or too little
   / how much is too much or too little #1
coolhl7
Panhandle Florida
MF1540HST
I have a 40HP HST
I was wondering (after all the warnings we read in manuals) how much extra oil is too much that it would cause problems? Is too much worse than too little???? just kind of curious........Thanks.
   / how much is too much or too little #2
There should always be room for the oil to expand. To much oil in an engine will cause hydraulic lock.
I know this for a fact on a small engine. I had a Honda air compressor, and I went to start it one day, and it just locked up. My first thought was to check the crank case, and sure enough as I removed the oil check plug, gas and oil came out. I am guessing the needle seat in the carb was leaking, and all the gas leaked down into the crankcase.
If to low on oil, you might not be able to move the tractor, or raise the loader.
   / how much is too much or too little #3
It's too much oil if it causes a problem, otherwise, it's just right.
CAT 336 D, Cab, Heat/Air Excavator (A52384)
CAT 336 D, Cab...
2001 J ODell 16ft Enclosed T/A Trailer (A51691)
2001 J ODell 16ft...
2015 Ford F-450 Cab and Chassis Truck (A51692)
2015 Ford F-450...
2013 Big Tex 16GP-20 Gooseneck Trailer (A53117)
2013 Big Tex...
2018 Ford F-150 Ext. Cab Pickup Truck (A51692)
2018 Ford F-150...
2016 Ford F-450 Ext. Cab 4x4 10FT Flatbed Truck (A51691)
2016 Ford F-450...
