how much is too much or too little
   / how much is too much or too little #1
coolhl7
Bronze Member
Panhandle Florida
MF1540HST
I have a 40HP HST
I was wondering (after all the warnings we read in manuals) how much extra oil is too much that it would cause problems? Is too much worse than too little???? just kind of curious........Thanks.
   / how much is too much or too little #2
There should always be room for the oil to expand. To much oil in an engine will cause hydraulic lock.
I know this for a fact on a small engine. I had a Honda air compressor, and I went to start it one day, and it just locked up. My first thought was to check the crank case, and sure enough as I removed the oil check plug, gas and oil came out. I am guessing the needle seat in the carb was leaking, and all the gas leaked down into the crankcase.
If to low on oil, you might not be able to move the tractor, or raise the loader.
   / how much is too much or too little #3
It's too much oil if it causes a problem, otherwise, it's just right.
2015 INTERNATIONAL PROSTAR (A53843)
2015 INTERNATIONAL...
JOHN DEERE 608C LOT NUMBER 19 (A53084)
JOHN DEERE 608C...
Miscellaneous electrical stands (A53117)
Miscellaneous...
Kubota SVL95-2 High Flow Cab Skid Steer (A53473)
Kubota SVL95-2...
2019 Polaris Ranger 900XP 4x4 Utility Cart (A51691)
2019 Polaris...
Ford Super Duty FX4 Pickup Truck Bed (A51691)
Ford Super Duty...
