How much is this used Mule worth?
   / How much is this used Mule worth?
After further inspection, I decided this wasn't the right Mule for me. The search continues...
   / How much is this used Mule worth? #22
Lawrence, I'm sorry to hear that the Mule didn't work out. It surely had some things about it that were questions, but with the added accessories, the orignial owner easily spent $13k+ on that Mule. I can see that a lift kit was installed and the addon cab was probably $3500 or more. Add to that the aluminum wheels and you are getting into the $13k to $14k new range. As all the others have explained, the front tires are of great concern as well as the 4WD. Otherwise, the bed appears to have little wear and the rest of the Mule just looks dirty. I can assure you that I can get a Mule that dirty in less than a hour after a rain storm. Yes, the dealer should have cleaned it up and also put on new front tires, but if the Mule was in otherwise good condition, it would have been a good buy, a little over 1/2 the new price.
Of course, I'm curious if you saw and tested the Mule. If you don't mind, tell us a little more about your reasons for not buying it.
I didn't make it over to do a full inspection of this mule. I spoke to someone on the phone who wasn't extremely forthcoming about any details of the mule. Combine that with getting busy and not being sure this is the right time to buy made me pass on this one. Thanks for everyone's opinions.
2005 EZ-GO Utility Cart (A55851)
2005 EZ-GO Utility...
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
2019 GALYEAN 150BBL STEEL (A58214)
2019 GALYEAN...
2020 Peterbilt 367 (A55973)
2020 Peterbilt 367...
Year: 2017 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 101,691 Plate: Body Type... (A55853)
Year: 2017 Make...
2012 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A57880)
2012 FREIGHTLINER...
