How much is an '03 Kub BX22 worth?
   / How much is an '03 Kub BX22 worth? #1
Bubba8992
New member wants guidance on what this rig is worth. I bought it in 2005from a fella who sold it as a result of divorce...without really thinking about whether I needed it or not. Too big to use around my house with lots of trees, rest of the 9 acres too steep for me to feel comfy using it. Still has most of the factory paint on the buckets. Prefer not losing my shorts in the deal! Are there sites out there I can get a value approx? Ebay only has one BX advert to compare.
Thx--Bill
Kubota 2003 BX22 4x4 SCUT with LA-210 FEL (48" bucket w/tooth bar), 60" MMM and BT-600 BH (12" bucket). 155 hrs, 4 way FEL valve, ROPS fog lights, mulch kit + new blades, middle buster plow, 2 lift cylinders for a top and tilt set up, workshop manual, lots of extra lynch pins and other parts. Purchased new in 2003 and always garaged.
Also have a 16’ tandem axle trailer, 2" x 3" channel-steel construction, rated for 7,000 lbs. (less the 1285 lb. trailer weight). It has brakes on 1 axle, full width ramps and was purchased new in 2004.
   / How much is an '03 Kub BX22 worth? #2
I would perhaps start at something around $12,500 -$12,900, and see what you get for interest. If it's really clean you should make out ok. You will most likely end up selling it for less than that..... I did.
   / How much is an '03 Kub BX22 worth? #3
Where you located??
KB
Located in Cincinnati, OH. Have an interested party in Lebanon, OH, but haven't gotten together yet.
Thanks for the guidance.
2017 Nissan Pathfinder SUV (A50324)
2017 Nissan...
2005 Ford F-150 Pickup Truck (A51692)
2005 Ford F-150...
2012 TRAVIS 39FT DUMP TRAILER (A52576)
2012 TRAVIS 39FT...
2001 Dodge Ram 3500 4x4 Knapheide Flatbed Truck (A51692)
2001 Dodge Ram...
2018 Ford F-150 Pickup Truck (A51692)
2018 Ford F-150...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50323)
BW RVB3405...
