How much HP needed?
/ How much HP needed? #1
rickou812
How much HP is needed to run this pump:
1.04/0.52 HYDRAULIC DOUBLE PUMP
New BONDIOLI & PAVESI double hydraulic gear pump. Aluminum housing.
SPECIFICATIONS
Disp. 1.04/0.52 cu. in. / rev.
Pump Type Gear
Rotation CW
Pressure 3300 PSI cont.
Speed 3500 RPM max.
Flow 7.6/3.8 GPM at 1800 RPM
Mount 2 bolt SAE A
Shaft 5/8" diam. 9T spline
Common Inlet Port SAE 16
Outlet Ports SAE 10
Size 7-1/4" x 5" x 4-3/8"
Shpg. 13 lbs.
Thanks
Texaco Gas Pump Yard Art (A64557)
Texaco Gas Pump...
TAYLOR S/A LOOSE LEAF TRAILER (A64278)
TAYLOR S/A LOOSE...
2011 Ford Explorer 4X4 SUV (A64557)
2011 Ford Explorer...
JOHN DEERE QUICK HITCH (A64278)
JOHN DEERE QUICK...
PACER 2" PUMP, BRIGGS & STRATTON ENGINE, HOSE (A64276)
PACER 2" PUMP...
UNUSED JCT-72" HYD TILLER (A65055)
UNUSED JCT-72" HYD...
