How much (HP) is enough?
   / How much (HP) is enough? #11
Zimmerer's chart says 2.5 acres/hour with a 5' mower and 5 mph. But since my tractor is supposed to have a top speed of 5.3 mph in mid-range and that wasn't near fast enough to suit me yesterday, so I went to high range and had to have been running most of the time at 7 mph (3.5 acres/hour) or more and didn't stop for any breaks, it just don't compute. Looking at Zimmerer's chart again, it looks like you used the 2.4 acres/hour at 6 mph with a 4' cutter????
Bird
   / How much (HP) is enough? #12
Bird,
The options are:
Zimmerer's charts are way off./w3tcompact/icons/frown.gif
Your mower is really only has a 4 ft blade./w3tcompact/icons/frown.gif
Your speedometer(?)is fast. /w3tcompact/icons/smile.gif
You have more land than you thought. /w3tcompact/icons/smile.gif
You are mowing your neighbors yard, too. /w3tcompact/icons/smile.gif
It is a long way from the barn to the mowed area. /w3tcompact/icons/smile.gif
You are taking long breaks when your wife thinks you are working. /w3tcompact/icons/smile.gif
Seriously, I have just used their data to get in the ballpark. They have a lot of errors in the data, but you can usually figure it out.
If you figure you get a 4 ft cut with a 5 ft mower then 55 trips per acre and 220 ft per cut is 12,100 feet or 2.29 miles traveled per acre or 2 acres/hour at 4.6 mph. I suspect he doesn't allow as much overlap as we do.
Got a lot of rain this weekend. About 3 inches of it came down in a deluge and washed away about $200 of roadbase on the driveway. Also have a little coastal growning through the perimeter fence. /w3tcompact/icons/smile.gif Glad to see 4.5 inches of rain. That should hold things for about 3 weeks! /w3tcompact/icons/smile.gif
   / How much (HP) is enough? #13
Wen, I go for the first option./w3tcompact/icons/laugh.gif And yep, 3.85" out to last awhile anyway.
Bird
   / How much (HP) is enough? #14
Yeah, I am afraid my wife will see the charts, because I have never made them either! /w3tcompact/icons/smile.gif If she complains that will be sufficient justification to get a bigger mower! /w3tcompact/icons/smile.gif
2012 PETERBILT 388 WINCH TRUCKS (A58214)
2012 PETERBILT 388...
2013 ISUZU NPR STAKE BODY TRUCK (A58017)
2013 ISUZU NPR...
2014 MACK PINNACLE (A55745)
2014 MACK PINNACLE...
air compressor (A55758)
air compressor...
MODEL 14C SCRAPER (A58214)
MODEL 14C SCRAPER...
MAGNUM LIGHT TOWER (A58214)
MAGNUM LIGHT TOWER...
