How much horse power(vehicle) needed to pull 1000 tons weight trailer?
   / How much horse power(vehicle) needed to pull 1000 tons weight trailer? #1
Aung Thu
I need to move 1000 tons weight stone about 300 km. And I want to know how much horse power(vehicle) needed to pull 1000 tons weight trailer? And also need to calculate it?
   / How much horse power(vehicle) needed to pull 1000 tons weight trailer? #2
1000 tons = 2,000,000 pounds:eek:
   / How much horse power(vehicle) needed to pull 1000 tons weight trailer? #3
im assuming metric tons. that's 2.2 million lbs. just for the record.
it would require at least 3 semi trucks, and a massive trailer with 20 or more axles in the states.
   / How much horse power(vehicle) needed to pull 1000 tons weight trailer? #4
Some places call a ton (metric ton) 2200 lbs.
   / How much horse power(vehicle) needed to pull 1000 tons weight trailer? #5
Something is missing here. You are asking how much horsepower to move 2000000 lbs. You need to go talk to a heavy hauling trucking company. I hope the stone is worth moving!
   / How much horse power(vehicle) needed to pull 1000 tons weight trailer? #6
If this big stone is being move down a hill, you need more brakes than HP!
   / How much horse power(vehicle) needed to pull 1000 tons weight trailer? #7
I hope this is a joke.
   / How much horse power(vehicle) needed to pull 1000 tons weight trailer? #8
Sounds like a school homework question.
   / How much horse power(vehicle) needed to pull 1000 tons weight trailer? #9
The simple answer is, "enough".
The question in my mind is, are you moving one stone that weighs 1,000 tons or many stones that total up to 1,000 tons?
   / How much horse power(vehicle) needed to pull 1000 tons weight trailer? #10
you'd probably have to try to rent this. The Crawlers | NASA even a mining truck could only carry less than half 1,000 tons. even then, try to get one of those on a road!!..
Transmission and Transfer Case (A50325)
Transmission and...
GORBEL EASY ARM LIFTING ARM (A52472)
GORBEL EASY ARM...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
2012 JOHN DEERE 10-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A52748)
2012 JOHN DEERE...
2018 Caterpillar CS54B Smooth Drum Vibratory Dirt Compactor (A51691)
2018 Caterpillar...
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
