how much grease from a grease gun ?
   / how much grease from a grease gun ? #1
glalonde
Woodlawn (near Ottawa), Ontario
JD790
Being new to the tractor world, is there a trick on when to stop pumping the grease into a fitting ?
Also, is there different pressure requirements for differenting fittings i.e. will a small grease gun do the same job as a large one ?
   / how much grease from a grease gun ? #2
I usually stop when I see new grease coming out in most cases. There are some spots that have sealed bearings that you don't want that. For instance my blade spindles on the MMM are sealed so I just give them a squirt.
As long as you can get the grease in, the size of the gun does not matter.
   / how much grease from a grease gun ? #3
On most fittings, I keep pumping until I hear the "squirt".
However, check your manual for any special grease requirements, for example, the pumpkin on my PTO shaft takes 25-30 pumps of grease every 8 hours of use.
   / how much grease from a grease gun ? #4
One thing that hasn't been mentioned. On things like tie-rod ends, there's a rubber seal that will swell as you pump grease in. Don't over do these seals. When you see it start to swell, that's enough.
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
2 - WEATHER GUARD TOOLBOXES (A55745)
2 - WEATHER GUARD...
2015 Ford Taurus AWD Sedan (A55853)
2015 Ford Taurus...
2025 Swict 72in Bucket Skid Steer Attachment (A55851)
2025 Swict 72in...
2020 Ford Explorer AWD SUV (A55853)
2020 Ford Explorer...
2013 FREIGHTLINER CASCADIA (A55745)
2013 FREIGHTLINER...
