how much grease from a grease gun ?
   / how much grease from a grease gun ? #1
glalonde
Bronze Member
Woodlawn (near Ottawa), Ontario
JD790
Being new to the tractor world, is there a trick on when to stop pumping the grease into a fitting ?
Also, is there different pressure requirements for differenting fittings i.e. will a small grease gun do the same job as a large one ?
   / how much grease from a grease gun ? #2
I usually stop when I see new grease coming out in most cases. There are some spots that have sealed bearings that you don't want that. For instance my blade spindles on the MMM are sealed so I just give them a squirt.
As long as you can get the grease in, the size of the gun does not matter.
   / how much grease from a grease gun ? #3
On most fittings, I keep pumping until I hear the "squirt".
However, check your manual for any special grease requirements, for example, the pumpkin on my PTO shaft takes 25-30 pumps of grease every 8 hours of use.
   / how much grease from a grease gun ? #4
One thing that hasn't been mentioned. On things like tie-rod ends, there's a rubber seal that will swell as you pump grease in. Don't over do these seals. When you see it start to swell, that's enough.
2004 CATERPILLAR 140H MOTORGRADER (A51406)
2004 CATERPILLAR...
2005 Mercedes-Benz C-Class Sedan (A50324)
2005 Mercedes-Benz...
2004 GREAT DANE 53FT DRY VAN TRAILER (A52141)
2004 GREAT DANE...
Wolverine Quick Attach Post Driver (A50515)
Wolverine Quick...
Skidloader Forks (A50774)
Skidloader Forks...
2021 ASV RT-135 Forestry Posi-Track High Flow Compact Track Loader Skid Steer (A50322)
2021 ASV RT-135...
