how much gear oil for a woods RC-5 rotary cutter?
   / how much gear oil for a woods RC-5 rotary cutter? #1
tjklein
NJ
none
Going to change out the gear box fluid - how much gear oil should I get??- also manual says 80 or 90 but can I use 75-90 and also what brand do you guys rec.- thks
   / how much gear oil for a woods RC-5 rotary cutter? #2
I use Amsoil Severe Gear 75/140 in my Kubota mower. Takes about 1 qt. Buy a couple of qts to be sure that you have enough. You can save the leftover oil for the next time.
Have you figured out how to get the oil out yet? I used a small hand pump to suck the oil out…. I change it every even year.
You could measure what you get out and simply put the same amount back in.
   / how much gear oil for a woods RC-5 rotary cutter? #3
I prefer John Deere corn head grease or "0" grease for gear boxes. It is what I have/use in ALL my gear boxes.
   / how much gear oil for a woods RC-5 rotary cutter? #5
In my new (last year) flail mower, I used 75/140 full synthetic. It came in a "bag" with a spout that was easy to install. It took one quart. I use 75/140 because it's typically hotter here than anywhere else in world except maybe the Sahara Desert. :rolleyes: The 75W allows full lubrication for the early season cool mornings too.
   / how much gear oil for a woods RC-5 rotary cutter? #6
Should be a drain plug on the bottom of the gearbox. If it'e leaking, the Corn head grease. If it's not, any gear oil, brand irrevelant.
   / how much gear oil for a woods RC-5 rotary cutter? #7
Any grease vs no grease. Any grease wins. :)
   / how much gear oil for a woods RC-5 rotary cutter? #8
Only if it's leaking. Regular grease won't liquify and will cause the bearings to fail from lack of lubrication. Corn head grease on the other hand liquifies as it warms up and provides lubrication to the bearings.
   / how much gear oil for a woods RC-5 rotary cutter? #9
The first thing I do is drain the oil and replace it with 00 picker grease. Low enough viscosity to lube the nooks and cranny’s but stiff enough not to drip out of the seals
2015 RAM 5500 Bucket Truck w/ Versalift SST40 boom -Cummins Diesel - Auto Trans- 4X4 - 72096 miles (A53472)
2015 RAM 5500...
2016 HINO 268 26FT BOX TRUCK (A52141)
2016 HINO 268 26FT...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
2020 New Holland 105 Workmaster MFWD Compact Tractor with 632TL Front Loader - Poultry Special (A53472)
2020 New Holland...
2020 CHEVROLET W4500 16FT REEFER BOX TRUCK (A52576)
2020 CHEVROLET...
