how much gear oil for a woods RC-5 rotary cutter?
/ how much gear oil for a woods RC-5 rotary cutter? #1
tjklein
Member
NJ
none
Going to change out the gear box fluid - how much gear oil should I get??- also manual says 80 or 90 but can I use 75-90 and also what brand do you guys rec.- thks
/ how much gear oil for a woods RC-5 rotary cutter? #2
I use Amsoil Severe Gear 75/140 in my Kubota mower. Takes about 1 qt. Buy a couple of qts to be sure that you have enough. You can save the leftover oil for the next time.
Have you figured out how to get the oil out yet? I used a small hand pump to suck the oil out…. I change it every even year.
You could measure what you get out and simply put the same amount back in.
/ how much gear oil for a woods RC-5 rotary cutter? #3
I prefer John Deere corn head grease or "0" grease for gear boxes. It is what I have/use in ALL my gear boxes.
/ how much gear oil for a woods RC-5 rotary cutter? #5
In my new (last year) flail mower, I used 75/140 full synthetic. It came in a "bag" with a spout that was easy to install. It took one quart. I use 75/140 because it's typically hotter here than anywhere else in world except maybe the Sahara Desert. :rolleyes: The 75W allows full lubrication for the early season cool mornings too.
/ how much gear oil for a woods RC-5 rotary cutter? #6
Should be a drain plug on the bottom of the gearbox. If it'e leaking, the Corn head grease. If it's not, any gear oil, brand irrevelant.
/ how much gear oil for a woods RC-5 rotary cutter? #7
Any grease vs no grease. Any grease wins. :)
/ how much gear oil for a woods RC-5 rotary cutter? #8
Only if it's leaking. Regular grease won't liquify and will cause the bearings to fail from lack of lubrication. Corn head grease on the other hand liquifies as it warms up and provides lubrication to the bearings.
/ how much gear oil for a woods RC-5 rotary cutter? #9
The first thing I do is drain the oil and replace it with 00 picker grease. Low enough viscosity to lube the nooks and cranny’s but stiff enough not to drip out of the seals
2012 Ram 2500 4x4 Crew Cab Pickup Truck (A59230)
2012 Ram 2500 4x4...
Bobcat 435 FastTrack (A60462)
Bobcat 435...
10ft. Inflatable Fire Rescue Boat (A59231)
10ft. Inflatable...
2014 Forest River Rockwood Premier 2317G S/A Pop Up Trailer (A59231)
2014 Forest River...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59230)
iDrive TDS-2010H...
43024 (A59228)
43024 (A59228)
