How much do you have invested?
   / How much do you have invested? #11
we was going for the hp and a heavier tractor.the 5 seris tractors was as high or higher than the 6s.
   / How much do you have invested? #12
I know I'm "old school" but I fail to see the big advantage of all the electronically controlled functions on a farm tractor that is submitted to all the dust,vibration & moisture. I'll take a mechanically controlled hyd valve over electronic controlled any day.
   / How much do you have invested? #13
tx jim im of the same thinking of you.but with most all new tractors theres no way to get awqay from the computers and electronics on new tractors.
   / How much do you have invested? #14
I agree with the tier 4 engines one will get a computer controlled engine but that doesn't mean trans & hyd's have to be electronically controlled. I saw a post the other day pertaining to a JD 6430 with a failed computer to the tune of $2500 + labor.
   / How much do you have invested? #15
my 7040 has a computer in it and i hope that it doesnt go out.
   / How much do you have invested? #16
My M7040 has a CPU also but I think the engine will run and trans & hyd shuttle will operate with the CPU disconnected. Nothing is mentioned in WSM about CPU in the electrical troubleshooting section.
   / How much do you have invested? #17
I understand where you're coming from. Normally, I feel the same way about gadgets. After putting 500 hours on this JD, I still love the convenience of the electro-hydraulic 3PH. It's especially nice when running the renovator plow. Get to the edge of the field, punch the "up" button, turn around and punch the "down" button. Plow goes back to the same level.
The only problem that I've experienced with this tractor has been the hydraulic manifold and pump assembly had to be replaced, but that's mechanical. And it was caused by a faulty casting on the manifold. And, JD did it under warranty.
2025 GPS Trailers (A56857)
2025 GPS Trailers...
Enerpac RCS302 30-Ton Hydraulic Jack, 5" Tall (A59076)
Enerpac RCS302...
Central Machinery Horizontal/Vertical Bandsaw, S/N 366852447, 120 Volt (A59076)
Central Machinery...
2013 PETERBILT 386 (A58214)
2013 PETERBILT 386...
Link-Belt 75X3 (A53317)
Link-Belt 75X3...
UNUSED FUTURE 40" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 40"...
