How much do these cost anyone seen one ?
   / How much do these cost anyone seen one ? #2
Price the rubber too
Bobcat modified a skidsteer to a tracked design (not the track over wheel conversion) The big one is a T300. Anyway, a magazine reviewed it and said that the track will outlast a premium set of tires on a regular skidsteer but the track replacement was $3500! I hear that those tires don't wear so well on a regular one so outlasting them may not be much comfort.
   / How much do these cost anyone seen one ? #3
I had an Oliver OC-3 with a 68" tread width. It didn't tip over, but sure would slide down the hills real fast when you got on a pole lying in the leaves. Of course I could have cured that by bolting on pieces of tires cut to fit the track segments. But when the rod came through the block, I gave up amateur bull-dozing. /forums/images/graemlins/crazy.gif
2006 Volkswagen Jetta Sedan (A55758)
2006 Volkswagen...
2019 Caterpillar 259D Compact Track Loader Skid Steer (A55973)
2019 Caterpillar...
Ford 655C 2WD Cab Backhoe (A56435)
Ford 655C 2WD Cab...
2012 TALBERT 4-AXLE RGN TRAILER (A58214)
2012 TALBERT...
CAT D8 (A58214)
CAT D8 (A58214)
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A56435)
2014 Doyle Dry...
