How much compost?
/ How much compost? #1
Duffster
Elite Member
Wisconsin
I am starting a new garden on a lot that had hay made off of it from as far back as I can remember until about 7 years ago when it started being mowed as lawn.
I can buy finished compost from the local metro solid waste agency and was wondering how much (by volume) I should apply.
My intention is to apply it this fall and have it rototilled in.
/ How much compost? #2
have you done a soil test yet to determine what you REALLY need?
cant say i have and i just dump about 5-10 heaping scoops of composted horse manure on mine each fall/winter.
/ How much compost? #3
Duffster
Yes, do a ph test to see if you need to decrease the acid level.
Lime to treat acid soil. Or, acidic sulfur to treat an alkaline condition. Just like a pool. :D Takes a month for these modifiers to work.
That said, you would love to have compost an inch thick or more over your garden. If your bucket is 1/3 yard, 3 buckets to a yard?
If your garden is 20 x 40, for example, you would want at minimum 2 yards. Personally, I would work in compost now, lots of it. 2" thick. I would also stock pile a yard for a fresh coating in spring to be worked in again. No sense making two trips. Maybe get another yard for other areas of the property. Flower beds, trees, etc?
/ How much compost? #4
Duffster
I think it would be difficult to get too much compost worked into your soil. Especially if you are amending a heavy clay soil. For the first couple years you can really pile it on and work it in. Plants do grow very happily on a compost pile. Compost as you are talking about probably isn't very hot nitrogen-wise, but a test (or ask the facility manager) wouldn't hurt.
Dave.
/ How much compost? #6
I am under the impression that if you put compost on in the fall and rototill it in hoping to give next year's garden a boost, most of the nutrients will be gone by next spring as they will rot and decay over the winter. The snow and/or rain will leach out most of the nutrients in a few months. Any grasses that are alive after the tilling will be stronger and harder to kill next spring. I would concentrate on killing the grass and its root system first this fall so you can start with a clean slate in the spring.
However, you can work on soil improvement this fall. Kill the grass, till it a few times and see what you have. You may need to add sand, clay, loam, certain types of compost, etc... depending on the soil type to improve its ability to hold water or drain water, depending on the case. Take some soil samples to your local county extension agent. They should be able to analyze it and tell you what to add to improve it.
/ How much compost?
That kind of what I wanted to hear. The new garden is 2800 square feet so I would need 9 yards @ 1" deep which is about how much I can haul at one time.
I guess that is what I was thinking but was wondering how much I would need to be worth the effort.
I did spray with Round Up 2 weeks ago and everything is nice and dead now. My intention is to not rework the ground in the spring other than a light harrowing so I would just assume work in everything this fall.
I may side/top dress the rows in the garden next summer with more if I have time and then go to a no till garden possibly.
/ How much compost? #8
Definitely get at least the ph tested or do it yourself with a home soil test kit.
1" of compost won't even be noticeable after you till it in. This is a new garden I would go 4-5" and till it in. If your garden is not in an area where winter winds will blow it all away I have put down 4-5" in the fall and just left it on top. This suppresses all the early spring weeds and grasses. Then give it a till and lay out your rows a week or so before you are ready to plant. You could even plant right through it if doing transplants. Once the plants are up and doing good I go back and sidedress slow release fertilizer and compost 2" or so thick around the plants to help suppress weeds close to the plants and help hold moisture. Eventually the weeds do punch through but your plants get a good headstart. The more compost in your soil the better the tithe and the easier it is to weed :)
/ How much compost? #9
I get city compost, too. It is mainly composted yard waste, with some shredded pallets included. It typically tests very low for nitrogen, but my interest is in the tilth it gives to my soil when I get enough tilled in. I have soil with good nutrient value, as determined by soil analysis, but it is too clay-like in consistency. It dries like concrete after heavy rains. The compost is ideal for improving that aspect of the soil. I get it by the pickup load, and I use a whole load to amend the soil in about 2-3 raised 4x24 foot beds. After a year or so I need to add another batch to bring the soil level back up after it settles and the compost is incorporated. For my purposes, I wish I had just ordered a full dump truck load of compost. You can never have too much! Even though the city says in their description that it is intended as a soil amendment, rather than a growth medium, one flower bed I made for the wife was just pure compost about 0.5-1.5 feet deep to which I added a couple handfuls of 13 13 13 fertilizer. The flowers darn near took over the house.
Chuck
/ How much compost? #10
The only consternation I have about leaving a layer of anything on top for the winter is the slowing of soil temps in spring. Wisconsin, like the NE or Michigan where I live is a bit slow to warm up in spring. This ain't Kentucky or even Southern IL or Ohio.
We don't want an insulator blanket or sun shield on it. We need to actually furrow up our ground. This accomplishes a couple of things. It doubles the amount of freeze/thaw cycle, a good thing if there is any clay at all. It more than doubles the surface area allowing for more area of sun exposure to the soil in April and May. Think of this as the same principle as raised bed gardening. Deep valleys and high furrows will allow for up 2 weeks earlier produce setting and thus, picking.
I know this goes beyond the question asked, but it reinforces the need to do your supplementing in fall. Get it tilled and get it furrowed up for the winter. Your veggies will love you for it next July.
/ How much compost? #11
That makes a lot of sense. Another thought, soil with a high percentage of compost will be 'lighter' and will dry out a bit quicker. I was always told, a wet soil is a cold soil. Since most typical garden seeds germinate best around 70 deg., the sooner your soil hits that temp, the better. You guys down south can laugh, but in the northern areas it makes a difference.
The people with raised bed gardens around here put the rest of us to shame this past summer, it was a long, cool and wet Spring.
Dave.
/ How much compost? #12
Really depends on when you want to plant. Around here foxtail and other weeds can literally grow all winter. By the time the soil is warm enough to plant vegetables it is already covered with new growth weeds. Leaving the compost on until right before you need to plant keeps these weeds from getting ahead start. Compost is also darker than my soil so it likely helps warm the soil some.
/ How much compost? #14
Five years ago I had 20 yards of Ann Arbor, Michigan city compost tilled into my 36' x 100' foot clay-based garden. Everything grew like crazy. This spring I got another 20 yards delivered. It was not as "composted" as prior, and had a lot of visible leaf matter and chips visible. This years garden was very slow to establish, and it wasn't until about 6 -8 weeks into the growing season that I recognized that the plant leaves were pretty yellow indicating nitrogen deficiency. Two weeks after 12-12-12 fertilizer and a few sprays with Miracle Grow things slowly turned around. At first I attributed the slow growth to our cool summer, but I am convinced that the compost just wasn't "composted" enough and it was binding up the available nitrogen. The clay is easier to work, but next year I will plant in the spring with 12-12-12 a couple inches below the transplants/seeds.
/ How much compost? #15
We generally add it in the spring and till it in. Our soil is reallysandy so it leaches pretty bad. This year we tried something different though and had the best garden ever. We did the usual mixing of finished compost into the soil, then, after we planted or the seeds were up a bit I top dressed each bed with about 2 inches of compost. It worked amazing. I think the black compost attracted the sun causing warming but at the same time it kept the soil from drying out too fast and leached "vitamins" to the plants.
That is my theory anyhow - whatever happened, we had a good crop.
Good luck Duffster.
/ How much compost? #16
I asked my wife; she is a Master Gardener and designer.
Without more details on your soil, she said put 2-4" of compost down, till it, and plant a cover crop. In the spring, till the cover crop, and add another 2-4" of compost.
It would be nice to get planty of compost, put some on, and then let the rest of the pile cook down over the winter. Especially if it is municipal stuff; we have got that before, and it was not fully composted.
/ How much compost?
Thanks for all of the suggestions. With all of the recent rains I think I will being doing good just to get the garden tilled this fall.
If I do get the compost on this fall it will be 1" or 2" at the most and maybe more next spring/summer. I could possibly spread some after it freezes and leave it on top. Either way I will probably stay away from the cover crop as I really am going to try to get away with not tilling again in the spring.
If we would happen to get a real nice November I may spread 2" of compost and have it tilled and then spread an application of manure and have it retilled, will just have to see how the weather goes next month.
/ How much compost? #18
When we're putting in new garden area, we mow close then cover with cardboard/newspaper and cover that with compost to a depth consistent with what would be planted the following spring, say 6 or more inches. As someone said in a prior post, try to keep your unplanted areas covered with cover or green manure crop. We use buckwheat for quick cover around 30 day turn around and annual rye for over wintering. Remove the rye before it seeds.
Have fun with your garden and try not to have your tomatoes cost you too much. :)
/ How much compost?
I don't think the cover crop is a good idea for this area.
It seems it would be best to leave the ground bare for the winter.
/ How much compost? #20
I'll put in a plug...
Check with your local Master Gardeners. They could tell you. They are volunteer gardeners who work with the state Universities and AG extensions(My wife is a Master Gardener).
The could tell you how much, when, and what to do for your local area.
Welcome to the Wisconsin Master Gardener Program
John Deere 6200 Tractor (A64047)
John Deere 6200...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
Schulte SBW800 Rock Windrower (A63118)
Schulte SBW800...
John Deere 2840 Tractor (A64047)
John Deere 2840...
3PT WEIGHT DRUM W/ CONCRETE FILLER (A63291)
3PT WEIGHT DRUM W/...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
