BoylermanCT
Veteran Member
- Joined
- Apr 1, 2013
- Messages
- 1,513
- Location
- Barkhamsted, CT
- Tractor
- Montana R2844, New Holland TC29D, Hustler X-One
According to specs, my Montana R2844 FEL will lift 2,360lbs to 59" and 1,585lbs to 90". The 3 point hitch can lift 2,619lbs at the ends.
The heaviest loads I lift are around 1400-1500lbs which is an IBC cage of green oak firewood. I currently have 5' King Kutter II rototiller as ballast, which is about 650lbs. When I lift the firewood cages, seems like there is still a lot of weight on the front axle, I leave ruts in the grass.
Would 1,000 lbs or 1,500 lbs ballast be the right weight? 2,000 lbs?
