How many watts for a single socket porcelain ceiling fixture?
   / How many watts for a single socket porcelain ceiling fixture? #1
newbury
Super Star Member
From Vt, in Va, retiring to MS
Kubota's - B7610, M4700
I've got a lot of single socket porcelain ceiling fixtures scattered throughout my buildings. All installed before my time. In most of these areas I would like a LOT more light.
Looking on the web it seems all of them are probably rated "660W" but probably came with a sticker or annotation to put no more than 100W (or less) in them. But they are located so I can't see the base easily. They are ceiling fixtures.
I've bought a couple of "splitters" on Amazon, single male socket bases with multiple female sockets (3 and 5), both had 1 sticker on them advising using 60 Watts Max. Further perusal on Amazon indicates that is a per female socket thing. Thus on the 5 female socket fixture it seems rated for 300 Watts (5x60) of bulb.
So I put 4 "100 Watt LED Equivalent" bulbs (actual consumption 13.5 watts @) in the 5-way fixture and screwed it in. As I figured, it looked like the sun compared to the old single 60 watt incandescent I had there previously. Rated at 5,200 lumen for the 4 LED total compared to 800 lumens. But wattage consumption is less.
Which got me to wondering how many watts (using LEDs) is it safe to pump through one of the porcelain fixtures? I've also seen 1 male/7 female fixtures which would let me throw almost 10,000 lumen from one socket.
   / How many watts for a single socket porcelain ceiling fixture? #2
I wouldn't worry - you will go blind from the LED output before you overload the porcelain fixture.
   / How many watts for a single socket porcelain ceiling fixture? #3
If you are going to use LED's it will never become an issue.
   / How many watts for a single socket porcelain ceiling fixture? #4
Power (in Watts)= I (current) x E (voltage). A typical socket is probably supplied by a 15A 110V supply so it could, in theory, provide 1650 Watts of power, or enough to power about 122 LEDs of the 13.5 watt variety.
   / How many watts for a single socket porcelain ceiling fixture? #5
Most have a claimed rating of 660w. That being said the rating could be anything on yours. The evil will he heat. If you plan to push these little Edison sockets add a little lube to the threads and keep an eye on things. I don’t want to see you standing in front of a smoldering pile of rubble winning a Darwin Award.
Why not just wire in proper fixtures? It will be cheaper and easier in the long run.
<snip>
In some of my areas ANY wiring requires a licensed bonded electrician.
Screwing in a $12 "spitter" in my unfinished basement storage room and 3 $2 bulbs which will last for decades is definitely cheaper and easier than getting an electrician out here. Now if you want to arrange and pay for installation of a "proper" fixture that can probably be arranged.
   / How many watts for a single socket porcelain ceiling fixture? #7
I've never seen a high watt LED bulb. I run 300 watt bulbs in the porcelain fixtures without burning anything yet. If you find a LED of 300 watt equivalent I'd like to know. The 300 watt bulbs are prone to blowing in a non fixed mounted fixture. Edit, they do make a 300 watt LED equivalent but the price is a long ways apart, and I don't like the color as much.
   / How many watts for a single socket porcelain ceiling fixture? #8
There's 2 considerations:
Amperage and heat.
Amperage:
(5)-13.5 Watt bulbs = 67.5 Watts total.
67.5 Watts / 120V = .56 amps of currents. Hardly noticeable on a 15 or 20 amp circuit.
Heat: With incandescent lights, you can assume that most (>98%) of all the energy used is converted into heat. Not only does the fixtures conductors and sockets have to handle the amps, but it also has to handle the heat load that's cooking it too. If the fixture can handle a 100 Watts light bulb's heat, or even 330 Watts, the LED's 67.5 Watts (the most heat the LED's could theoretically generate) is no problem.
Note that in the summer, the energy consumption for an incandescent is even worse than the wattage listed on the bulb, since many people then run their air conditioner to remove the heat the bulbs create. However in the winter, while LED's save on your electric bill, they bump your heating fuel bill up. :rolleyes:
Yes, up to a few weeks ago I couldn't find any 100 watt LED's in a price I would pay. Then Amazon had them on sale 4 for $14 and I bought them. I've a few places where only 1 A19 style bulb will do.
<snip>However in the winter, while LED's save on your electric bill, they bump your heating fuel bill up. :rolleyes:
The way you wrote that it almost reads like they cool the house. They just don't help heat it as much :)
UNUSED FUTURE WALK BEHIND POWER TROWELL (A52706)
UNUSED FUTURE WALK...
2020 MACK PINNACLE (A58214)
2020 MACK PINNACLE...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
New/Unused SD Lanch 20x20 Carport (A57454)
New/Unused SD...
2018 Elgin Broom Badger Sweeper, Kubota Turbo Diesel Engine, mounted on 2018 Isuzu NRR Truck, VIN (A59076)
2018 Elgin Broom...
Terms & Conditions of (Buying through EquipmentDealz Auction) (A59213)
Terms & Conditions...
