How many stuck center links do you have?
   / How many stuck center links do you have? #1
stuckmotor
Super Member
Lower Up State S.C.
AC WD 34 hp/3500 lbs MF 261 60 hp/5380 lbs
Anybody ever get a really stuck top link back loose and adjusting easily. Is there a trick to it or am I doomed to have a collection of stuck top links? I've tried heat and a months long soak in PB Blaster.
Signed,
Stuckmotor and a few other things
   / How many stuck center links do you have? #2
Try soaking in 50/50 mix diesel fuel and ATF.
   / How many stuck center links do you have? #3
By "center link", do you mean the Top Link of the three point hitch?
If you do mean Top Link do not let it make you crazy. Take your existing Top Link or its measurements to Tractor Supply or Agri Supply and buy a Category 2 replacement for less than $25.00
I coated the threads on my Kubota Top Link when new with anti-seize compound. Anti-seize did not help, however, when I bent the Top Link.
CountyLine® Adjustable Top Link, Cat. 2 - Tractor Supply Online Store
http://www.agrisupply.com/Top-Link-Long-Cat/p/11902/&sid=&eid=/
Xfaxman,
That soak might work. Thanks.
Jeff,
You are correct, I meant "top link". I constantly get that mixed up. I believe you've come up with the ultimate solition. :) Thank you.
   / How many stuck center links do you have? #5
Sometimes they can bend. Like if using a rear blade, and pushing in reverse (or backing into something with ANY attachment), and having it extended any length at all. Sometimes the bend is barley noticeable but enough they turn hard.
   / How many stuck center links do you have? #6
I've never come up against a rusted/stuck threaded bolt or rod that heat would not bust loose unless the threads are completely gone. Did you use an O/A torch?
   / How many stuck center links do you have? #7
Signed,
Are you talking about the draft control spring assembly on the top link?
   / How many stuck center links do you have? #8
It could be bent. It doesn't take much of a bend to stop the threads from going in and out.
Unfortunately, I don't have an O/A torch handy. I used a homemade carbon arc torch with my Lincoln tombstone apparently I need more heat than it's putting out.
No Kid,
Just the top link. One end is stuck and won't screw in or out.
Adams 5 T Spreader (A53473)
Adams 5 T Spreader...
23222 (A50323)
23222 (A50323)
2011 Hyundai Sonata Sedan (A51694)
2011 Hyundai...
2007 Ford F-550 Crew Cab 11FT Flatbed Truck (A51692)
2007 Ford F-550...
2018 Ford Explorer AWD SUV (A51694)
2018 Ford Explorer...
2016 KENWORTH T270 S/A SERVICE TRUCK (A51247)
2016 KENWORTH T270...
