how many shims behind the motor pulley
   / how many shims behind the motor pulley #1
heehaw
russellville, arkansas
Kubota M4900, B7510 and RTV
those of you that have replaced the motor on your troybilt tillers: do you remember how many shims you had to put behind the motor pulley?
heehaw
   / how many shims behind the motor pulley #2
You need to shim to line up the upper and lower pulley V grooves, it varies from engine to engine. Try the amount you had from the old engine and work from there. A short piece of steel rod or tube in the v will help you to see if it ligns up correctly.
IRTPL 10,000 LBS TWO POST LIFT (A58214)
IRTPL 10,000 LBS...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
2007 International 4300 Box Truck, VIN # 1HTMMAAL27H513415 (A57453)
2007 International...
Takeuchi TB016 (A53317)
Takeuchi TB016...
2010 MAXEY WELDING 20 T/A GOOSENECK TRAILER (A55745)
2010 MAXEY WELDING...
19088 (A55758)
19088 (A55758)
