Front-End Loader How many reason to have a FEL!!!!
   / How many reason to have a FEL!!!! #11
Helps me get my Mother-in-Law out to the backyard for cookouts
   / How many reason to have a FEL!!!! #12
To hang your deer from during hunting season.
To save your back lifting heavy items out of the pickup.
And all previously mentioned.
   / How many reason to have a FEL!!!! #13
The FEL also gives you a nice platform to gut out a deer so you do not have to bend over(for old guys), also helps in skinning and cutting up deer. The cutting edge of my bucket go up 8+ feet.
   / How many reason to have a FEL!!!! #14
Ha, I should have read this about six months ago! As the first post stated --use to raise the front end up to change tire-- I suppose that would have been easier than rolling a 3 ton floor jack about 300 yards into the woods and down a hill to remove the front tire and take to get repaired. I knew it would lift the front end but for some reason, PO'd? I didnt think of it.
   / How many reason to have a FEL!!!! #15
How 'bout to add front-end ballast to balance out those heavy rear implements?:D
   / How many reason to have a FEL!!!! #16
Having your wife hoist you up so you can change the flood lights on the side of the barn.
For the OSHA police -- I added an 8" plate to the top edge of the bucket, so it hits you right about butt high and you can lean into the bucket and use the supporting pipes for a handhold.
   / How many reason to have a FEL!!!! #17
Big @$$ old fence post puller.
   / How many reason to have a FEL!!!! #19
LarryD said:
How 'bout lifting the front end of the trencher your neighbor rented and walked back into the trench. :eek:
Glad to see i am not the only one that's done that!!!
   / How many reason to have a FEL!!!! #20
carry water
pull T posts
carry T posts
Push T posts into ground
hook buckets onto bucket hooks for carrying supplies and tools for fencing
pick up 2800 lb concrete culverts, place them where you want a corner post
hook chains to toothbar for carrying
stand in while cutting limbs
put chair in, sit in chair, buddy drives, spray herbicides on undesired plants
uncover dirt from septic tank, attach chain to handle, lift lid
put PVC container in hollow round crossbrace, use to carry chains
PVC container in hollow frame support, insert fire extinguisher
slip toothbar under something heavy, chain it to bucket, lift and carry
attach chains to hocks of rogue, shot yearling bull, place into pickup bed
hook toothbar teeth into upper crossbar of gate, hold in place for manual insertion of gate hinge pin
brace bent metal, use FEL to straighten out... a gate, for instance
put rocks in it and wander off to a slough place
2023 RAM 3500 4DR 4X4 CAB AND CHASSIS (A56138)
2023 RAM 3500 4DR...
2018 E-Z Beever M12R Towable Brush Chipper (A51691)
2018 E-Z Beever...
19010 (A55851)
19010 (A55851)
2022 Carry-On 5'x8' Trailer (A53316)
2022 Carry-On...
2009 Ford F750 Reel Loader Truck (A52377)
2009 Ford F750...
2019 Ford Fiesta SE Hatchback (A55853)
2019 Ford Fiesta...
