How many bottom plow per horsepower?
   / How many bottom plow per horsepower? #1
porky1
Central Va.
JD 5103
What is the general rule of thumb for figuring horsepower per bottom??? Thanks
   / How many bottom plow per horsepower? #2
Don't know what the rule of thumb is but I had no problem pulling an old 2-bottom plow with my last 25 HP 4WD rig.
   / How many bottom plow per horsepower? #3
15-25hp per bottom depending on plow size and soil condition.
   / How many bottom plow per horsepower? #4
My dealer said 1-1.5 hp per inch as a guide.
   / How many bottom plow per horsepower? #5
I have an really old "Ferguson" 2 bottom plow, I think a 16", and it takes a minimum of 50hp to pull it through my hard clay soil. I can tell you from experience that a 30 hp tractor will not come close to beginning to pull my plow, unless you only plan to plow about 4 or 5" deep. My plow is a beast, does a great job, but requires quite a bit of hp to plow a good 12 inches or more. 25 hp would never move it in my soil. Heck, 30 hp would't. I have to add weight and my FEL on the front for more weight and my 50 hp doesn't pull it any too easy. I'd call 50 hp about "adequate" for my plow.
   / How many bottom plow per horsepower? #6
In my book there isn't any! It depends on your soils type and the amount of compaction. Here in NY from one valley to the other it might take 100 horse to pull a 4 bottom and in the next valley you can do it with 50 horsepower. There is also a difference of the tractors and there balance as well as the tractors draft control. Clay pulls hard and slow whre other soils you could pull faster by three mph with the same set-up. Why do you ask?
   / How many bottom plow per horsepower? #7
Gosh guys you're not saying that the Chinese builders put more HP in their tractors than other counterparts are you? Here's a picture of the little 25 HP 4 WD package that used to pull our 2 bottom Dearborn before we traded up to a 40HP New Holland. I honestly had no problems and never knew it couldn't be done either. /forums/images/graemlins/grin.gif
   / How many bottom plow per horsepower? #8
Back on the farm a two bottom plough used to require 4 horses.
Egon /forums/images/graemlins/grin.gif
   / How many bottom plow per horsepower? #9
A 25 hp tractor can pull a 2 bottom plow (what size bottoms are you pulling?). But it can't pull a 2-16 in hard clay. Different soils require more or less hp from the same tractor plow config. I can pull my 3-16 with my TN 65 but my ground is not hard clay. I know in hard clay I will be in my slowest gear and hope that I can pull the plow thru. Hope this clears it up some which is why there is such a big hp window in the "rule of thumb" for a plow.
   / How many bottom plow per horsepower? #10
That's a right, there are many variables when using a moldboard plow. One of these are also plow design, some are a lot easier to pull than others.
Pair 2 new 8' pallet fork extensions (A53421)
Pair 2 new 8'...
2005 Ford Focus Sedan (A51694)
2005 Ford Focus...
JOHN DEERE 5115M TRACTOR (A51243)
JOHN DEERE 5115M...
2015 Ford Escape SUV (A53424)
2015 Ford Escape...
2022 MAXXD BD14 Heavy-Duty Dump Trailer with 14K GVWR and Tandem Axles (A53473)
2022 MAXXD BD14...
