How many Attachments?
/ How many Attachments? #1
bill9068
Evansville Indiana
Kioti DK5510, Kubota BX25D, Bobcat S130, Bobcat 742.
Counted mine the other day and was surprised I had 11. Don’t remember getting them all, but got them over time. I’ve got a 2018 Kioti DK5510 shuttle and a Kubota BX25D. I have 3 buckets, harrow disc, flail mower,
grapple,cultipacker,cultivator, forks,stump bucket, box blade, ballast box’s and a back hole for the BX. I’ve sold a 3 point chipper and a bush hog I never used.
/ How many Attachments? #2
I have 5 if I counted correctly. I’d like a couple more but don’t need them that bad.
/ How many Attachments? #4
Baler
two hay rakes
disks
chipper
root rake
bedder/tool bar
grapple
bucket x2
finish mower
double bottom plow
middle buster
spreader
towed sprayer
forks
bale spear
backhoe
Had to type it out just so I could count, 17. Number kind of shocked me a bit, I didn't think I had that big of a problem :oops:
/ How many Attachments? #5
As a few of these comments have indicated, how many implements and attachments you will have will largely depend upon how you use your tractor.
My count is 7 implements (3ph mounted) with additional under consideration for some future projects and 2 attachments (FEL mounted).
Comparisons of number of implements/attachments has more to do with what and how the tractor is used and how each is used.
Point in case, I do not do haying, thus have no use for bale spikes, hay rakes, hay baler, hay tenders, hay mowers, etc. However, if for some reason I would start haying, that would all change, and would result in an increase in the number to a doubled (or greater) amount.
Make that 12, forgot the plow.
/ How many Attachments? #7
Finally got it down to 2.
/ How many Attachments? #8
We have two tractors so a few doubles,two two bottom plows,two rear blades,two bush-hogs,box blade,potato plow,cultivator,york rake,snow plow and thumb on bucket of one tractor.
Forgot a cultiapacker and grain drill. So 14
/ How many Attachments? #10
This question caused me to count them-now I know why my wife thinks I have an implement “problem”
JD MX-7
Ford 917 flail
Rototiller
Disk harrow
Spreader
Chipper
Pallet forks
Grapple
Front bucket
/ How many Attachments? #12
1) Bushhog
2) Finish Mower
3) Box Blade
4) Grader Blade
5) Plow
6) Boom Pole
7-?) Disk - Recently sold and might replace
/ How many Attachments? #13
9. With the box blade being on the tractor most, followed by the rotary cutter next. Then the FEL stuff.
Box blade
Drag harrow
Angle blade
Cultivator
Single plow
5 ft rotary cutter
Pallet forks
5 ft material bucket
3 pt scoop bucket
/ How many Attachments? #15
Pretty interesting topic after I started thinking about it. Someone mentioned above they may have a problem. Once I started counting, I realized I'm not far behind. Between my brother and I we have a nice little collection.
3 tractors
Mowing machine
Tedder
Rake
Baler
Bale spears
Bucket
Grapple
Pallet forks
Straight blade
Landscape rake
Box blade
Brush hog
Posthole digger
Pig pole
Subsoiler
Potato plow
Drag
Stump grinder has been ordered
Would like an offset flail mower and rototiller.
/ How many Attachments? #16
3 tractors
Mowing machine
Tedder
Rake
Baler
Bale spears
Bucket
Grapple
Pallet forks
Straight blade
Landscape rake
Box blade
Brush hog
Posthole digger
Pig pole
Subsoiler
Potato plow
Drag
What is a pig pole?
/ How many Attachments? #18
I might have had a problem with Craig's List years ago... (well, "had" might not be correct as I still look...) :ROFLMAO:
In the list below the *** means that I plan to sell these someday. I thought about putting a ckeck mark on which implements that my wife knows about!?!
After-Thoughts
1chipper shredder; Bush hog
1500​
would not buy againUsed***
2tiller; 5' King Kutter
900​
would not buy againGave away
3backhoe, Long 1199
750​
4finishing mower 6' Bush Hog
750​
Most helpfulUsed
53 spool valve; Prince MB31BBB5C1
740​
Most helpfulNew
6Top-N-Tilt
500​
Most helpfulUsed
7posthole, 6"/9"/12"
400​
would not buy againNew
8grapple; WR Long BOG Single
350​
Most helpfulUsed
9fert. Spreader
275​
Little usageUsed
10ditching blade; 6'
250​
Little usageUsed
11rough cut mower, 5' LandPride
250​
Good purchaseUsed
12box blade, 6'
250​
Good purchaseUsed
13ratch rake, 6'
200​
Little usageNew***
14yardtool pulverizer; 5'
200​
Little usageUsed
15disk; 4'
200​
Good purchaseUsed
16Stabilizer arms; Kubota
175​
Good purchaseNew
17forks , 3ph; Agri-Supply
150​
Good purchaseNew
18cultipacker/seeder
150​
Good purchaseUsed
19hay spear
125​
Have not usedUsed
20potato plow; Agri-Supply
120​
Good purchaseNew
2116" plow
120​
Good purchaseUsed
22sub-soiler; Fred Cain
100​
Have not usedUsed***
23tooth bar; WR Long
100​
Good purchaseUsed
247' rake
100​
Good purchaseBuilt
25spike aerator
100​
Have not usedUsed/fixed
26HD toplink; Kubota
80​
Good purchaseNew
27cultivator
75​
Have not usedUsed
28quick hitch; HF
70​
Little usageNew
29sprayer
50​
Good purchaseBuilt
30scrape blade; 6'
50​
Good purchaseUsed
31carry-all
50​
Good purchaseBuilt
32sidewinder mower
15​
Have not usedUsed/homemade
33counter weight
0​
Good getBuilt
34trailer mover
0​
Little usageBuilt
35Water tank
0​
Good getBuilt
36Bucket brush forks; 4'
0​
Little usageBuilt
37blower
0​
Good getSalvage
38boom pole x3
0​
repairedgiven away all 3
39spike aerator
-230​
Not usedbought $30/sold $260
8975​
Total costs
spike aerator
/ How many Attachments? #19
I only have 2 (3 if you count the front bucket)
- 60” finish mower
- 60” brush hog
As you can guess, I mainly mow and haul stuff in the bucket like rock, dirt and mulch.
MoKelly
Yup.
Quick Hitch
Box Blade
Tiller
Landscape rake
I'm just a semi rural homeowner with 1 acre that I'm tired of landscaping with shovel, rake & wheelbarrow.
Now, on the topic of Gf's....
Happy Memorial Day Weekend all!!
Pick
/ How many Attachments? #20
JD MX-7
Ford 917 flail
Rototiller
Disk harrow
Spreader
Chipper
Pallet forks
Grapple
Front bucket
you say that ... like it's a bad thing :)
Unused 2021 Unused Paladin MD60SC 5ft. Rotary Brush Cutter Tractor Attachment (A66734)
Unused 2021 Unused...
953D GP Bucket (A68134)
953D GP Bucket...
2021 JOHN DEERE 333G SKID STEER (A65056)
2021 JOHN DEERE...
2004 INTERNATIONAL 4300 4X2 S/A  UTILITY BODY (A66091)
2004 INTERNATIONAL...
PORTA POTTY (A67714)
KIVEL TRAILER MOVER ATTACHMENT (A64553)
KIVEL TRAILER...
