How many acres can I mow per hour?
   / How many acres can I mow per hour? #21
The charts / mowing calculators I’ve found to include the above picture are all pretty accurate.
I wouldn’t say they have to 100%, but they provide a planning factor.
One thing I have learned to speed up mowing times is mowing in a circle starting at the center of the field.
Thanks, you get it, sometimes the little things can make a considerable difference.
   / How many acres can I mow per hour? #23
Why is that faster? Do you need the exact center so there's no cleanup on the edges, or is being sort of close still faster?
   / How many acres can I mow per hour? #24
I owned an empty 150' square lot in town for a few years that I mowed in a circler pattern with a 62" mmm deck on a JD garden tractor. It was a fun way to mow.
I don't remember it being faster, maybe it was, but I do remember it being easier. But saving the corners for last got frustrating with all the turnarounds and short runs.
   / How many acres can I mow per hour? #25
Probably because when mowing in a straight line from one end of the field to the other you spend a LOT of time turning round at each end, at which time the mower is not doing anything. Going round and round you never stop or turn around.
   / How many acres can I mow per hour? #26
Less wasted time turning when you might not be cutting a full cut.
You still have clean up cutting as the corners are left. I make about two perimeter rounds at the start then go to as near the center and start cutting in a circle.
I can’t use this technique in one of my pastures due to the shape of it and lots of trees.
On a side note with my pull type Woods C114 (9.5’ wide) I think it may be easier on my PTO joints as I don’t make as many tight turns (not relevant if you have a 3pt mounted cutter).
   / How many acres can I mow per hour? #27
I find the various calculators and charts to provide reasonable estimates as long as they include overlap and efficiency penalties.
Where they get particularly inaccurate in the real world is when people think they can maintain unrealistic speeds. My mower is capable of mowing at 10 mph, but on (16) 2 acre lots I can only AVERAGE about 4 mph mowing as fast as I can. My wide open 4 acre field I can average closer to 5 mph.
   / How many acres can I mow per hour? #28
Like others here, I do a good amount of mowing, and these charts are indeed pretty accurate. But you do have to use just a little bit of common sense, and some just don't have that or the natural skill. I sometimes have someone else running one while I'm on another. One guy is a natural, the other, while safe and respectful with the equipment, just doesn't have "the touch".
   / How many acres can I mow per hour? #29
I'm retired. So how fast I mow is of little concern. I mow at a speed that is - 1) enjoyable and 2) doesn't throw me off the mower.
Nuff said.........
   / How many acres can I mow per hour? #30
Nuff said.........
I wish I could post a video on here of how my tractor tosses and turns as I mow my desert acres. Much of the time I have to hold on to a grab handle just to stay in the seat. When I had only my old John Deere to mow with I used to stand up and use my knees as shock absorbers - just as I would when riding a dirt bike over rough terrain. But I can't stand up in the Kubota's cab!
SKID STEER ATTACHMENT RAKE (A58216)
SKID STEER...
Brock 48'x16' Flat Bottom Grain Storage Tank (A57148)
Brock 48'x16' Flat...
2015 FORD F-350 XL SUPER DUTY SERVICE TRUCK (A51406)
2015 FORD F-350 XL...
2009 CHEVROLET SILVERADO 1500 (INOPERABLE) (A58214)
2009 CHEVROLET...
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
New/Unused SD Lanch SDLE20 Mini Excavator (A57453)
New/Unused SD...
