How LOW can you GO?
   / How LOW can you GO? #1
Ginormous
Dayton, Ohio
Yanmar YM2210
Here's my question: how tall is your tractor with the ROPS up? I'm going to be putting up a barn, and I want to make sure the door for the tractor is tall enough -- I plan to have a separate entrance for the tractor that takes into account the concrete pad from a barn that used to be there.
   / How LOW can you GO? #2
I have 1" clearance on my 8 ft door, although the ROPS on my tractor is not standard and somewhat taller then standard, ;)
   / How LOW can you GO? #3
How high of a door can you put in ???
   / How LOW can you GO? #4
Think! Will I ever have a bigger tractor? Will I ever put new tires on my exsisting tractor? Will I ever add a roof or cab to my tractor? Will I ever put new lights on my ROP? :confused::confused:
Make the door as wide and tall as your plans will allow! After it's done it's harder to make them bigger then!
   / How LOW can you GO? #5
My 2210D just barely makes it in my (standard height) garage door w/the rops up. I mean, it touches the top of the door frame as it goes through. If it was one inch higher, I would have to take the pins out and fold it down...............
Sounds like a 10' door ought to cover me... unless I get completely crazy buying bigger and bigger tractors. :drink:
   / How LOW can you GO? #7
I specified a 10' door and in reality only got about 9'10". You would be amazed at all the ways contractors will try to lower your garage door. I was there every day and I measured and cracked the whip, but I still got shorted.
I would go for 11' just to be safe...
   / How LOW can you GO? #8
wrong contractors :D I would have request 10' 1 1/2 in the rough frame opening, By the time I add the 2x8 for the encasement you would have been right on the money, well except the 3/8 weather stripping that seals the door across the top and sides,;)
I do know what you mean though, I always had to remind the framers to take off that 1.5 inches,:mad:
   / How LOW can you GO? #9
I have a 336D with ROP and a metal cab (fabric sides) which extends above the ROP, I have 9" doors on the barn and clear it with some room to spare.
Joe
   / How LOW can you GO? #10
All I can say is don't add chains to the rear tires.;)
2012 CHEVROLET SILVERADO SINGLE CAB TRUCK (A51406)
2012 CHEVROLET...
2003 Ferris IS1000 52in Zero Turn Mower (A51691)
2003 Ferris IS1000...
2005 Chevrolet Colorado 4x4 Pickup Truck (A51692)
2005 Chevrolet...
2014 Freightliner Cascadia 125 T/A Sleeper Cab Truck Tractor (A51692)
2014 Freightliner...
Yale MPB040-EN24T2748 4,000lbs Electric Walk-Behind Pallet Jack (A51691)
Yale...
2004 Kenworth T800 Day Cab T/A Truck Tractor (A52377)
2004 Kenworth T800...
