How Low can I go?
   / How Low can I go? #1
Ranger Rick
Louisa, VA East of Charlottesville
Kubota L3940
We stopped using heating oil last year and I have been pumping the heating oil out of the tank into my transfer tank to fuel my tractor. The heating oil tank is now down to about 8 inches in the vertical tank. My question is how low can I pump out the tank without getting into whatever lurks in the bottom of a 30+ year old tank?
   / How Low can I go? #2
drain it off into 5g bucket and check out what you got in there.
you might be surprised.
might be able to pour 95% of it off thru a tshirt and then treat it and be fine..
the rest dump on the next fire pit...
   / How Low can I go? #4
I hope you are running it thru a good water trap and filter on your pump also. This should trap any particulate that would harm your tractor.
   / How Low can I go?
you might be surprised. might be able to pour 95% of it off thru a tshirt and then treat it and be fine..
Soundguy I have lots of old t-shirts, is that fine enough to get most of what might be in there? Should I look for a finer filter?
Gary, Yes I do have a filter on the transfer tank that does block water also.
Thanks for the ideas. Rick
   / How Low can I go? #6
You will clearly see water or algae as a "blob" lurking at the bottom of a bucket. Just let it sit for a hour or so.
Chris
   / How Low can I go? #7
yep.. the water will seperate.. and any algeae and debris will be sediments.. though the algea may flaot.
the doubled or trippled tshirt should grab sand and algeaa, and PROBABLY water.
the rest that pours into the 'clean bucket should be about as clean as you get out of your plastic 5g can.
from there.. treat it, and your tracotrs sediment bulb and primary or primary/secondary fitler for sure should catch the rest.
i know my diesel has a ? 5 micron final...
2018 PINSA 130BBL VACUUM TRAILER (A53843)
2018 PINSA 130BBL...
JOHN DEERE 6135RW401 MOTOR (A51247)
JOHN DEERE...
2013 3400QB SUNDANCE 5TH WHEEL CAMPER (A52472)
2013 3400QB...
2013 Cadillac ATS Sedan (A53424)
2013 Cadillac ATS...
Gooseneck Livestock Stock Trailer - Tandem Axle Ranch Hauler - Selling Absolute, No Reserve (A55301)
Gooseneck...
2020 INTERNATIONAL LT625 (A52472)
2020 INTERNATIONAL...
