How long will diesel keep???
   / How long will diesel keep??? #11
Diesel will last years without degradation. The biggest issue is not moisture, but water in the diesel will allow algae to form in the diesel. This can clog filters, etc. Most common path of moisture is temperature changes which between expansion/contraction of the diesel and condensing of airborne moisture (dew) in the fluid. Using an additive can absorb the moisture and inhibit algae growth. I buy a product from the local HVAC supplier, made for heating oil tanks. A few ounces will treat my 50 gallon plastic barrels. I had steel barrels in the past, but then I saw the amount of rust that accumulated at the air interface and switched to plastic. You should not seal the barrels since there is thermal expansion/contraction of diesel and you need to have room for that to prevent overpressure. The best solution is to use a desiccant breather on the tank, but that is expensive and needs routine service on the desiccant (replacement or heating to remove moisture). I have a small oiled breather (like an oil air cleaner) on my tanks to reduce moisture ingress.
paul
   / How long will diesel keep??? #12
If the tank is vented in any way, the tank will breath in and out with temperature changes and hence suck in moist air that under the right conditions will condensate.
I only ever had a problem with algie on my JD 770 and I suspect that such an occurance has much to do with the temperature of the fuel. Every **** part of the fuel system was filled with a nasty gell like substance. This, in the middle of summer.
I am very suspicious of any additives, because there is rarely a real test to see if it works as advertised. I'm sure it's a huge money maker. I am most suspicious, just as with Snake Oil that can cure just about anything, products that don't deferentiate between diesel and gasoline. You would think that the two would have entirely different requirments. I bought some seafoam on the weekend, and was dismayed that it doesn't even give the exact mixture saying it will treat between such and such an amount. What the ****? When I spoke with Lucas, I could get nothing close to REAL information about their products either! Just more PR BS!
One thing is for sure. Today's diesel is not anything like that of yesterday and seems to have a host of issues.
Just as a side note. Got a nice Makita 4 stroke leaf blower for X-MAs. Says in the manual that gasoline may spoil in a single day! What kind of crap are us consumers being sold these days??
   / How long will diesel keep??? #13
My only experience with stored diesel was in the early 90s when I parked my truck in my folks garage before a three year assignment to Okinawa Japan. It ran fine although the fuel consumption rate seemed a little high until I burned the tank away.
   / How long will diesel keep??? #14
I do understand that sentiment.
My own experience with Stabil in gasoline is after a year, it has the smell of old gas.....that varnish smell. PRI-G doesn't, even after 4-5 years. Both cases, sealed 55gal drums stored together in the same conditions ( which is to say in a cool, insulated shed )
Going by that smell alone, and no testing, I concluded PRI was the better product for gasoline.......and by extension, I assume the better product for diesel ( PRI-D )
PRI does web publish findings of some of their ASTM testing. I can't find anything for Stabil. Seafoam offers only customer testimonials.
PRI Advanced Fuel Treatments
I have no financial interest in any of the above companies or their products.
   / How long will diesel keep??? #15
How do 55 gallon drums allow for expansion of fuel, which always seems substantial? It's amazing how much plastic jerry cans can swell?
   / How long will diesel keep??? #16
I keep them in a fairly even temperature area.
   / How long will diesel keep??? #17
Don't know about the diesel, but know my furnace fuel oil tank was last filled in 1997. The furnace runs about 5 times a year, no problems. Hate to hear that thing start knowing the current price to replace that 87 cents/gal fuel being burnt.
Same here but the last time I filled, I added some gunk that is supposed to keep it from going bad. NAPA desk warned me that it was rather spendy (not bad, around $20). My comment was "as opposed to losing 300 gal of diesel?"
Dunno when my last fill was but it during the last jump in prices - I recall it was well over $4/gal.
Harry K
Case IH 1020 Platform (A50514)
Case IH 1020...
2013 Ford Explorer SUV (A50324)
2013 Ford Explorer...
UNUSED CFG INDUSTRIAL STSD10 QUICK ATTACH SEEDER (A51244)
UNUSED CFG...
Set of Tractor Tracks (A50514)
Set of Tractor...
2009 Yamaha YDRE Electric Cart (A50324)
2009 Yamaha YDRE...
Wolverine Quick Attach Hydro Slide Pallet Forks (A50514)
Wolverine Quick...
