How long should things last?
   / How long should things last? #81
Did the flashlight still work?
That was my first thought, too! The old batteries were zinc- carbon, non-alkaline, so dead, but they hadn't leaked. Two new D-cells, and "TaaDaa"! It worked.
It is on the backup shelf pending time to put an LED bulb in with a few more lumens.
All the best, Peter
   / How long should things last? #82
That reminds me. The house came with the original appliances. Say mid-80s. The dryer always had this clunking sound that I chalked up to out of round / old bearing. After we had had it for fifteen years, one of the thermal sensors went, so I bought two new ones, and opened it up to replace thermal sensors. Piece of cake, ten minute job. The icing on the cake was a D-cell flashlight that someone had left inside the dryer for me.
No more clunking! I do wonder how many decades the flashlight was in there.
We also always leave the washer and dryer doors ajar.
All the best, Peter
A year ago I was watching a service tech replace the detergent dispenser system on a one year old front load washer. He dropped a screwdriver down the front of the machine so it was in the bottom right front corner of the machine as you face it. He had to disassemble half the machine to get to that corner to fish it out. Added a good hour to the job.
Fast forward to last week, different service tech, that same detergent dispenser went out again, and, they had to change the bellows (big rubber ring) that acts as the door seal and gasket as well (mold). The guy removed the top, and about 5-6 screws and the entire front of the machine lifted off. I noticed easy access to the area where the other tech dropped his screwdriver. Would have been a 5 minute job. 🙃
   / How long should things last? #83
Yeiks…on a 1 year old machine. That’s horrible. I believe my kitchenaid dishwasher is now 5 years old, and has worked flawlessly. Super quiet also. But i do monthly cleaning cycles using affresh tablets (do this for both washer and dishwasher). I started to do this after i started to notice hard water buildup in unit. Since running this cycle monthly, no buildup any more. Stainless surface is super clean.
   / How long should things last? #84
Unfortunately, these new high efficiency washing machines require a lot of service. So do the new refrigerators. The name rhymes with phirlwool. 🙃
   / How long should things last? #85
We are around year 13 on our home now. Installed all LED bulbs and almost all are still origional. At that time they were expensive and most had metal housings and heat sinks. I remember wondering how the mfg companies would make any money if the bulbs lasted 20 years. They must have figured it out. I used mostly LED bulbs for our wedding venue when we remodeled 6 years ago. I am always replacing a few it seems like on these newer LEDs.
30 years in our house. I installed CFLs when we bought, and still have maybe a dozen of the originals. I replace them with LEDs as they fail, and have had no LED failures. Six years since I built my shop, and have had half a dozen 4' LED shop light failures.
   / How long should things last? #86
For me there are two questions being presented here.
How long should something last,
and how long should something be supported.
I have rarely had something that didn't last.
What I face, on nearly all fronts, are things that have been orphaned.
And they are orphaned at a much higher rate than they have worn out.
I am a bit strange in the sense that I have to maintain matching sets of things; like locks, and lights fixtures, and switches, bath fixtures and drawer handles, and doors and such. The orphaning of things really bugs me, cause, I can't replace the one failed item with something that doesn't match the others.
   / How long should things last? #87
Knowledge of what your working on really helps
I have one tech in my shop that i've about given up on. He's dumber than a stump.
If you tell him something to make his job easier..... he does the opposite.
He was replacing a starter solenoid the other day. I told him it's a 3 wire solenoid. So it grounds through the case. Do Not Hook the ground to the "I" post.
Small posts were labeled S and I. That means start post, and accessory post.
He comes back to me 20 minutes later complaining that the solenoid is bad.... it's not working.
I didn't even leave my office to go look at it.
I replied "You hooked the ground wire to the I post!!!!! Now..... do what I told you to start with and move the ground wire to the flipping frame bolt!!!!"
His reply " well it looked identical to the one I was replacing!!!"
My reply "just because it looks the same, doesn't mean that it is the same!!!!"
The posts are labeled, i've explained what they mean multiple times.
He's done some other really dumb stuff this week, so my my boss and I both have been all over his butt....
He's the only tech I've ever worked with that is fixing to get a demotion to "Yard Bi#ch" And made to start all over again.
   / How long should things last? #88
I have that with window gaskets, they stopped making them, but the windows themselves are in great shape. Just the gaskets crush over time.
   / How long should things last? #89
Sounds to me like it's time to hand him his walking papers.
   / How long should things last? #90
Fix it once probably cuz of my misuse of it anyway. Fix it twice its nearing its end life. 3x I get to destroy it with my mini x before I take it to the scrapyard. Recently blew the third discharge pump on my washing machine, still full of water of course plus the display on circuit board was no longer functioning. When I'm done releasing my frustrations on that contraption it should fit in the trunk of my winter beater for transport to scrapyard. On the positive side, Wife really likes her brand new washing machine.
   / How long should things last? #91
Factory Service can fail miserably…
Bosch Dishwasher… not draining and Service tech said cost to repair more than new and to buy a new one.
I did a quick internet search and found a $28 part might cure… and it did…
Another is a washer dryer stack where unplugging overnight cured the issue at hand and no $400 circuit board needed or 6 weeks lead time.
   / How long should things last? #92
I knew that I shouldn't have read this thread. One of the drawer tracks on my 30 year old Whirlpool broke. No replacement part is available. I glued it back together but it probably won't hold. This is a great fridge other than this problem.
   / How long should things last? #93
My ge monogram refrigerator had an issue years ago with freezer door ice dispenser not working. I called ge repair and someone called me back telling me its a known problem and id need an entire new door. Very costly. I did internet research and found that there was a printed circuit board inside ice maker door that can go bad. New board was under $30 on ebay. Took about 30 minute# to repair. A few years later it happened again. Wouldnt you know, the board is no longer available. However one without night light switch was. Only needed slight modification to turn on light while dispensing ice. I bought 3 extra boards.
   / How long should things last? #94
Unfortunately once someone gets past the 90 day probationary period, it's next to impossible to fire them.
It's much easier to run them off.
I see lots and lots of dirty jobs in his near future.
   / How long should things last? #95
@grsthegreat nice job!
@Dftodd sorry to hear about the employee hassle. I don't know whether to hope he loves the outdoor yard work, or not.
All the best, Peter
   / How long should things last? #97
You lucked out. IF you're handy, and IF you can find replacement parts...a couple of big "ifs".
As others have noted, parts and service documentation can be hard to find, especially when models change as rapidly as they do plus so many modern appliances aren't very easy to work on. I have a friend who used to run an appliance repair business, sold it and retired a few years ago and figured he got out just in time.
Tough to even find someone who does that kind of work anymore.
Same deal with electronics. What typically fails in flatscreen tvs is the backlighting. If you can get the parts, and if you're willing to take it apart you might be able to repair it, but if you have to pay someone to do it you might just as well buy a new one.
   / How long should things last? #98
So, true.
Personally, I like the challenge of finding problems, the proper parts or something I can make into a part, and repairing things. Same for building things.
Always have. No accounting for tastes I guess.
All the best, Peter
   / How long should things last? #99
I’m comfortable with mechanical controls which often can be repaired with the tools I have…
Mechanical often means 20+ years or older and diminishing.
I find sourcing is better in the Internet age… no way without would I be able to source obsolete parts worldwide…
As to ability… once I hear it can’t be fixed or not worth fixing it’s my green light… both as a challenge and also nothing to loose except maybe my time fooling with it.
   / How long should things last? #100
The unnecessary and expensive ECM on my Kubota mower appears to be dead and:
1. it shouldn't exist, because its entire job can be done with components costing under $2;
2. it costs $340+;
3. Kubota provides no schematic;
4. Kubota has not given its mechanics a method of testing it, so the test is to put a new ECM in, and if the mower doesn't run, you just spent $340+ on a part you can't return because...it's dirty. Either that, or you can spend a week taking out every single wire in the mower and checking it for continuity.
I bypassed it so the mower starts, and I have the components (cheap) to force the mower to perform the ECM's lost functions. The important ones, anyway.
JCB 507-42 TELESCOPIC FORKLIFT (A60429)
JCB 507-42...
2016 Yanmar VIO25 (A60462)
2016 Yanmar VIO25...
Booster Cables (A59230)
Booster Cables...
2016 INTERNATIONAL PROSTAR TANDEM AXLE DAY CAB (A59904)
2016 INTERNATIONAL...
2021 CATERPILLAR D3 LGP CRAWLER DOZER (A60429)
2021 CATERPILLAR...
167 (A52708)
167 (A52708)
