How long should a secondary mower belt last?
   / How long should a secondary mower belt last? #11
I stick with OEM belts ..... I learned the hard way on Pop's old Ariens YT11. Iirc Ariens used a unique belt pitch .... I went through a bunch of brand name belts (couldn't seem to keep belts on it) before I went back to OEM- the problem went away. I smoked the belt at about 50 hours on my '07 X320 after switching out the snowblower- it's one LONG belt that does the job of your two and I didn't check the routing carefully enough. At $60 or so to replace it you can bet I'm a lot more care on checking the belt routing these days. That JD replacement belt has a little over 600 hours on it and I'll have to replace it next season. If your pulleys and spindles etc. are in good shape, a JD belt should get you a lot more than 60 hours.
   / How long should a secondary mower belt last? #12
Have not replaced mine yet. 1100 hrs on the tractor so far.
2015 CATERPILLAR RM300 ROAD RECLAIMER (A52705)
2015 CATERPILLAR...
2016 Nissan Frontier Ext. Cab Pickup Truck (A55788)
2016 Nissan...
2013 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A54313)
2013 FREIGHTLINER...
Hyster H225E Forklift (A47477)
Hyster H225E...
2023 Chevrolet Tahoe (A54815)
2023 Chevrolet...
2011 John Deere 5075 4WD Agricultural Tractor (A52377)
2011 John Deere...
