How Long for Calcium Chloride Rust-Through?
   / How Long for Calcium Chloride Rust-Through? #1
AndyinIowa
Central Iowa
Kubota BX2350
I've read a lot of people set against CaCl for ballast due to corrosion. At the same time, the only personal experiences I have with fluid filled tires leads me to believe that most rims will take 15+ years to corrode to the point of causing downtime.
Is the 15 year number typical for what everyone else is seeing? My FIL's 8N has over 23 years without problems. I haven't seen any rust-through problems with rims built since 1992...
IowaAndy
   / How Long for Calcium Chloride Rust-Through? #2
IowaAndy
The rims can't corrode if the CaCl isn't leaking from the tube. It is as simple as that.
   / How Long for Calcium Chloride Rust-Through? #3
15yrs min sounds about right. The 2010 has tubes, but little leaks occur so the rims stayed wet w CaCl for many yrs. Lots of corrosion but still plenty strong. I cleaned and painted them when I replaced tires&tubes 10yrs ago.
larry
   / How Long for Calcium Chloride Rust-Through? #4
If they filled the tire up so that the fluid is OVER the rim top on the inside they will last a LONG time even without a tube. As long as no oxygen gets to the metal no rust can happen. Maybe air up with Nitrogen only>? Lots of tractors with fill in them for 30-60 years and still holding air.
   / How Long for Calcium Chloride Rust-Through? #5
20 years for my Uncle's L2250.
2009 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2009 Ford F-150...
2025 IR UNUSED Hydraulic Thumb (A53117)
2025 IR UNUSED...
20 ft. Shipping Container (A53117)
20 ft. Shipping...
CAT 973 (A47384)
CAT 973 (A47384)
PAIR OF FILING CABINETS (A53843)
PAIR OF FILING...
2004 Fleetwood Wilderness Advantage 365 BSQS 38FT T/A 5th Wheel Travel Trailer (A53424)
2004 Fleetwood...
