How Long for Calcium Chloride Rust-Through?
   / How Long for Calcium Chloride Rust-Through? #1
AndyinIowa
Central Iowa
Kubota BX2350
I've read a lot of people set against CaCl for ballast due to corrosion. At the same time, the only personal experiences I have with fluid filled tires leads me to believe that most rims will take 15+ years to corrode to the point of causing downtime.
Is the 15 year number typical for what everyone else is seeing? My FIL's 8N has over 23 years without problems. I haven't seen any rust-through problems with rims built since 1992...
IowaAndy
   / How Long for Calcium Chloride Rust-Through? #2
IowaAndy
The rims can't corrode if the CaCl isn't leaking from the tube. It is as simple as that.
   / How Long for Calcium Chloride Rust-Through? #3
15yrs min sounds about right. The 2010 has tubes, but little leaks occur so the rims stayed wet w CaCl for many yrs. Lots of corrosion but still plenty strong. I cleaned and painted them when I replaced tires&tubes 10yrs ago.
larry
   / How Long for Calcium Chloride Rust-Through? #4
If they filled the tire up so that the fluid is OVER the rim top on the inside they will last a LONG time even without a tube. As long as no oxygen gets to the metal no rust can happen. Maybe air up with Nitrogen only>? Lots of tractors with fill in them for 30-60 years and still holding air.
   / How Long for Calcium Chloride Rust-Through? #5
20 years for my Uncle's L2250.
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2018 Chevrolet Silverado 3500HD 4x4 Crew Cab 9FT Flatbed Truck (A51691)
2018 Chevrolet...
2009 Mazda 3 Sedan (A51694)
2009 Mazda 3 Sedan...
greenworks (A53421)
greenworks (A53421)
Ford F550 (A53422)
Ford F550 (A53422)
