Buying Advice How long can I get by without one?
   / How long can I get by without one? #21
I think the OPs relationship with the man he's borrowing the tractor from is unique. I'm not sure anyone posting has that relationship. I think that's why Dad can't understand why a tractor needs purchased.
That might be easier explained if the purchased tractor better fills a need.
Yep. My dad loves helping put with his tractor. He's on it almost every day. I just see myself doing a lot of loader work and the HST would be nice. I thought of getting rid of my ZTR and getting a compact that could also serve as my mower.
As for a 75+ HP, not only is that not in the budget ($30k and under ), it isn't necessary since as someone pointed out most of the ground isn't tillable. Mostly we do timber work and ground work. Not mowing.
   / How long can I get by without one? #23
I have 20 acres and have a 40 hp tractor. I would not want a smaller machine. Processing firewood, a bit of driveway maintenance, snow blowing, food plots.
You will regret trading the ZTR...it mows at double the speed. IMHO.
   / How long can I get by without one? #24
Yep. . He's on it almost every day. .
There is the answer to your question on how long you can do without ?
If he is always on it you need one now because he is stealing all your fun tractor time!
   / How long can I get by without one? #25
I think 30k or less would by a nice tractor that would do a lot of things you need. The argument goes on and on about a ZTR vs a tractor with a MMM vs a tractor with a rear finish mower. They all work great but it depends on your needs. I like the mid mount on my JD 2025r, it is also an auto connect so it goes on and off the tractor easier. For price I got a 2025r, FEL, 60 autoconnect deck, and pallet forks for 21 k taxes and all, 0% for 5 years so a 30k budget would by a lot of tractor new or used.
   / How long can I get by without one? #26
A SCUT with an MMM or RFM will mow, but probably isn't a substitute for a dedicated mower in most cases. I was hoping it would be, but it just isn't. My ground is rough, lots of imperfections. When it gets dry in Summer, it's very hard. That makes for a hard ride on my SCUT with filled R4 tires. Very hard .. to the point I can't comfortably mow at any sort of speed. Just bounces me around in the seat around too much. And the turning radius isn't great for getting around and between things. I also need a minimum of 8' clearance under branches due to the ROPS. Most dedicated mowers are much lower.
A SCUT isn't really suited for tilling and timber work on any scale. I till and move wood, but only on a very small scale.
For price I got a 2025r, FEL, 60 autoconnect deck, and pallet forks for 21 k taxes and all.
Mine was around $18K with the MMM, FEL, BH, 48" tiller and subsoiler/middlebuster.
   / How long can I get by without one? #27
I think with the OP’s budget he is looking at what is more likely a CUT sized tractor.
   / How long can I get by without one? #28
I think if a larger class tractor with FEL is purchased Dad will quickly change which tractor he's on daily.
Tillage isn't why you would benefit from a larger tractor. Timber work is where the need is.
In your backyard picture alone I see a couple hours of heavy grapple work with a larger more stable tractor. :)
   / How long can I get by without one? #29
Get a cab tractor. Dad is getting older and whether he likes it or not he will be much safer (wind, dust, heat, cold) and more comfortable in a cab.
   / How long can I get by without one? #30
Getting back to the original question...
Only you know what your finances are like. If you can easily afford a new tractor you will never regret it. Having access to your father's JD puts you in a postion to look around, but there's something to be said about owning your own tools and equipment. It took me a long time to realize that borrowing comes with a cost. Now if I can't afford to buy something I will go without. And what I do have I don't lend.
^^^^^ EXACTLY CORRECT !!!!
2023 Kubota L6060HST Compact Utility Tractor (A55315)
2023 Kubota...
2015 Ford Escape SUV (A56859)
2015 Ford Escape...
202474 (A54757)
202474 (A54757)
19088 (A55758)
19088 (A55758)
2014 Chevrolet Impala Limited Sedan (A55853)
2014 Chevrolet...
2013 Ford Edge Limited AWD SUV (A55853)
2013 Ford Edge...
