How long can cylinder rods remain exposed to the elements before they should be coated with something?
   / How long can cylinder rods remain exposed to the elements before they should be coated with something? #1
SylvainG
Platinum Member
South West, Qc
Kioti LK30
Knowing that:
  • My tractor has no shelter, therefore has to stay outside;
  • Some rods on my backhoe can't be fully retracted when parked;
  • During winter, I'll put a tarp over it once removed from the tractor to make way for the blower;
  • During summer, it will be mounted on the tractor and open to the elements;
  • I will definitively not use it every day and probably not even every week;
  • The only time there are salt here, is in winter, and on the road. Beside that, I'm over 450 km from the nearest salt water so salt isn't really an issue here.
How long can the rods be exposed to the elements before requiring being coated with something like Fluid Film to protect them against rust and pitting?
I'm thinking of 3D printing protective covers that will go from the cylinder end to exposed the rod end to protect them from the elements. Would that be enough?
   / How long can cylinder rods remain exposed to the elements before they should be coated with something? #2
Any cover I can envision would serve to trap moisture and exacerbate corrosion issues. Fluid film or common grease would do better. For usage like yours (and mine when I had a 3pt backhoe) I'd apply when you know the backhoe project is done and the next is still unscheduled.
   / How long can cylinder rods remain exposed to the elements before they should be coated with something? #3
This is right on topic for me. I just spent all morning on the Kubota cylinder rods buffing and polishing the rust off. I can tell you that three years is WAY too long to let them go unattended. :cry: My surgery down time put a lot of equipment on the long list.
   / How long can cylinder rods remain exposed to the elements before they should be coated with something? #4
My Kubota manual says to coat the exposed rods with grease for extended storage.
   / How long can cylinder rods remain exposed to the elements before they should be coated with something? #5
Like almost every other simply stated question on here. It depends on various factors that aren't that hard to comprehend. Environment is the biggest in this regard.
Putting grease on a cylinder could do more harm than good in my (thinking) opinion. It might make contaminents that could harm seals more likely to stick to the cylinder. Or make it harder for the seal to simply brush away the contaminent. I might grease a stored cylinder rod but I would also clean off the grease prior to retracting the cylinder.
But how long is 'extended storage' ? A week? Month? Year?
Thursday, I've coated the extended rods with hydraulic fluid, the same in the tractor. Yesterday was a rainy/windy day and the ground here is very sandy. I checked this morning and the exposed rods are covered with sand particles so yeah, it does stick to it. Planning on wiping the rods before the tractor next usage.
Fluid Film says it's not tacky so I'm not sure if this will be an issue but the removal of the product before use, that could be the issue. On an hold thread (2013), it goes from not removing it, to using Simple Green, Diesel and even brake cleaner o_O So I'm at lost at what to do to get rid of it. Someone said they used grease and wrapped the rod in paper and simply unwrap the paper before use. Not sure how well the greased paper would hold in rain, maybe wax paper would be more appropriate?
   / How long can cylinder rods remain exposed to the elements before they should be coated with something? #7
Store it inside!
No "extended storage" issues!
   / How long can cylinder rods remain exposed to the elements before they should be coated with something? #8
Everything you are concerned about is legitimate.
The issue is the quality of the chrome coating on the cylinder rod or rods. Dont count on it being a high quality chrome coating.
You can safely use grease or fluid film on the rods and tie news print to the exposed rods as an added measure.
The rod wipers in the packing glands are only as good as the chrome coating on the cylinder rod so keep that in mind when you have a lot of dust to deal with as it should be washed off it if at all possible when you are done digging.
You can always use Cosmolene and a Cosmoline stripper to protect the exposed portion of the cylinder rods. The issue is that the Cosmolene MUST to be stripped before the back hoe is used as the rod wiper would be damaged from the Cosmoline. I always used DL hand cleaner to break up the Cosmoline coating.
It would be simpler and cost less to coat the cylinder rods with brushed on fluid film and wrap them with newsprint using nylon twine to hold the newsprint tight to the cylinder rods.
If you use grease you have to be sure to clean the rods well to prevent any fine dust from getting pulled into the rod wiper.
Fluid Flm
Saran Wrap
4 or 5 wraps of newsprint you can also coat the newsprint with Fluid Film and then wrap it which lets it soak into the news print.
nylon twine tied in a spiral wrap using square knots
It is stored safely and the everything is easy to remove using a leatherman tool or the scissors on the Leatherman tool
Leon
   / How long can cylinder rods remain exposed to the elements before they should be coated with something? #9
I believe those rods are stainless steel so they won’t rust very easily
   / How long can cylinder rods remain exposed to the elements before they should be coated with something? #10
I greased my cylinder rods when I took my loader off. To clean the grease, you can wrap twine around the rod, then pull to the other end. It will then be free of grime.
Komatsu WA270-8 Articulated Wheel Loader (A49346)
Komatsu WA270-8...
Toyota 6FGU25 Forklift  5,000 lb Capacity (A51039)
Toyota 6FGU25...
2024 New Holland T8.410 MFWD Tractor (A51039)
2024 New Holland...
(INOP) CATERPILLAR 259D SKID STEER (A50459)
(INOP) CATERPILLAR...
2016 WESTERN STAR 5700XE TANDEM AXLE SLEEPER (A51219)
2016 WESTERN STAR...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
