How is it going with the improved finish mower decks?
   / How is it going with the improved finish mower decks?
Thank you "Z".
davek78063; Ah, "I see!"; said the blind man, as he picked up his hammer and saw. Your rear discharge mower is behind you. Ours are front mounted. Whole different story. My JD 650 has rear mount 60" medium duty groom mower with chain veil too.
prs
I would venture to say you could get high lift blades for the contour mower even if they aren't ventrac made. I would guarantee that ventrac makes high lift blades for the new 72" deck.
The three models of the new style mower are fitted with high lift blades. The rear discharge new model is factory fitted with low lift. This seems to be a consistent pattern with Ventrac and may be based upon problem with high lift blades on the rear discharge designs. So, i guess one could order high lift blades for the new rear discharge and give them a try, but I would expect (speculate?) the result would reveal just why Ventrac decided against it.
prs
OK, I dropped some coin and purchased an MS 720 with the hydraulic lift.
I did not trade the big contour, but may do so later if this works-out. I brought it home yesterday afternoon and have cut about 11 acres with it set at next to top setting (4 3/4 inches as measured by ruler in grass). It cuts evenly, did not scalp, and put less strain on the power unit. I thought I would not like losing that extra 12" of cut width, that the job would take longer. What I found was that my pace increased due to the lighter weight and lesser power requirement on my steep ground. Of course, the new deck is a rigid one piece unit; thus it does not "flex" to evenly hug contours such as road berms, golf sand traps, or ditch edges. Fuel use was so similar that I can see no difference there. The tractor did run cooler and I did NOT have to stop and clear the radiator screen, not even once. When I finished today, that radiator screen was only partially loaded as compared to the several stops I would have made with the rear discharge contour.
The hydraulic lift gets a mixed review from me. The operator does not just pull the secondary valve and "up she comes". You have to open the deck hood, lower the deck's cut height setting to minimum, pull three pins, then lift the tractor's front coupling to max, then finally operate the deck lift. So, I can manually flip-up the contour deck quicker; but it is a brute chore.
prs
Fimco 15 Gallon Sprayer (A54865)
Fimco 15 Gallon...
(INOP) JOHN DEERE TS GATOR (A51247)
(INOP) JOHN DEERE...
New/Unused Quick Attach Pallet Forks (A54865)
New/Unused Quick...
Venetian Bronze Aluminum Mailbox Post (A54865)
Venetian Bronze...
2017 Chevrolet Sonic Premier Sedan (A55853)
2017 Chevrolet...
2022 Club Car Tempo Cart (A55853)
2022 Club Car...
