How in the heck did that happen
   / How in the heck did that happen #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
Broke the bolt off somehow... It is cracked where the threads connect with shaft part of the bolt...
   / How in the heck did that happen #2
Hey Carl,
Is it a sign? That you need a Cat D6? :laughing:
I hope it didn't happen in a critical moment...
All the best,
Peter
I guess on the Over Torqued. Can't think of any other reason. Rest of the tractor is fine, and the truth is I haven't been stressing it. One big log the other day with the grapple.... hmmm.. I did pull over a big fur and slabbed it up... maybe that was it.
   / How in the heck did that happen #6
Looks like your using an after-market top link there. Wouldn't affect it, just noticing.
Do you know what grade the bolt that broke was?
   / How in the heck did that happen #7
It was probably a grade 2 bolt.
The upper link head may have a sharp edge and if a certain load was placed on the link, it might act like a shear.
   / How in the heck did that happen #8
On my 1845 I have bent numerous 3/4 inch bolts and also the bracket I had made so I could use a quick attach plate similar to the 422 quick attach plate. I am also using a regular tractor 3 point top link . I don't understand how I am bending the bolts the way I am.
   / How in the heck did that happen #9
No one has said the grade of bolt they are using.
It is possible to generate a lot of back force by ramming the bucket into something difficult.
Ramming could also cause a large spike of hyd fluid in the cyl, hoses, etc. Work port relief would help in that situation, maybe.
   / How in the heck did that happen #10
I used grade 2 bolts and I don't know what the pin would be. I only used the setup I have on the 1845 for hauling firewood and chips in the bucket, no hard use.
New/Unused Quick Attach Auger with Three Bits (A51573)
New/Unused Quick...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53472)
NEW HOLLAND 706 30...
2008 Hino 268 Truck, VIN # 5PVNJ8JV582S51513 (A51572)
2008 Hino 268...
John Deere 310K Backhoe (A51573)
John Deere 310K...
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A51573)
(1) HD 24ft Free...
Pallet of (11) 10 Lug Misc Wheels (A51573)
Pallet of (11) 10...
