How I water tree seedlings in dry weather...photo
   / How I water tree seedlings in dry weather...photo #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
003.JPGHere is how I water my tree seedlings during the dry spells. I put three 55 gallon plastic drums in the loader bucket and chain or strap them in. First I drilled a hole in the side near the bottom and installed a plastic farm-type petcock with a garden hose adapter on it. It does not leak but you need long arms to install. Be careful, barrels can fall out of the loader if you are not careful.
I can use a short hose and raise the loader or just use to fill 5 gallon pails. I put other five gallon pails around the trees in which I drilled a small--3/16?--hole in the bottom. Then the water can drip out slowly and it does the tree a whole lot better. Anyway, here's a photo.
   / How I water tree seedlings in dry weather...photo #2
Nice and your concept gives me an idea. This came to me because my FEL will only lift around 500lbs at a time, but I was thinking that I could get a handful of barrels and mount them on little pallets and drop one off why I go and fill up another one ..... and so on etc. That way after I have delivered three or four to their destinations, the first one will be empty and I can start the process over again.
Thanks for the inspiration Sixdogs
   / How I water tree seedlings in dry weather...photo #3
Nice setup... really nice tractor! I finally broke down and got one of those three point carry all things. Put some decking on it (literally, 5/4 deck boards on 2X4 stringers) and now I can throw my 55 gallon drum on. Used it just yesterday to plant a new batch of trees. There is probably room for more barrels but I don't know the weight limit of the thing. Gave me plenty of room for the barrel, a five gallon pail to water from, spade, the trees and my coffee mug!
RobS--- you have all the essentials and that is a great setup. The rear platform does work fine and that actually was my first choice but I already had the loader and the buckets fit so that was the path of least resistance. Using the loader I can lift the buckets ten ft in the air and use a hose that the wife can direct the water.
She is not willing to do this any longer and the five gallon water bucket with a small hole in the bottom actually works better.
I think the hole-in-a-bucket idea was a major discovery because I have not seen it mentioned before.--See my inital post here but it gets every bit of water into the root zone and no runoff.
I think water is 8.5 lbs per gallon so 55 gallons is 467 lbs and three of them is 1400 lbs. But , all of my trees have lived, other than the ones I mowed by mistake.
   / How I water tree seedlings in dry weather...photo #5
That's a great application with the barrels, Sixdogs.
Just thinking, instead of drilling a hole in the lower barrel section, would a pvc threaded adaptor fit in the bung hole? If so, then you could add the valves at the bung holes and not drill any more holes in the barrel. I hate cutting more holes in a good barrel. Of course, the barrels would have to be horizontal to work.
No can do Redbug--the barrels have no strength on their side. Upright is the only way. Barrels are cheap in the upper Greak Lakes area--they are old soy sauce containers from Wisconsin and you can buy for maybe $5-$7 each if you buy five.
I also cut the tops out --leaving the edge of the barrel intact for strength --and use to haul bulk fertilizer. And who knows, if the recession worsens I could add suspenders and save on farmyard attire.
   / How I water tree seedlings in dry weather...photo #7
I don't have any picture of it but we've got a 275 gallon plastic tank. I think it's used for watering or chemicals as it has a 8" or so opening on the top of it and a shutoff with a 2" outlet (if I recall) on the bottom edge.
Its sitting permanantly on a little trailer so I just hook it up to the tractor, fill the tank with water and go on my way.
We've taken the outlet and fabricated a hose attachemt for it...actually two attachments. One is for a singular hose and the other will allow 4 hoses to be attached.
It was this tank that saved our blueberries from last years drought. I probably carried 1,000 gallons to them and let it soak in. (I use a soaker hose and not a regular hose).
Anyways... makes it easy to carry & deliver as long as you don't mind gravity feed.
   / How I water tree seedlings in dry weather...photo #8
Nice idea, but for me with 400 newly planted 2-0 trees, I might run out of buckets!
Bob
Bob
Dr Bob,
That's where you lift the bucket, attach the hose and try to get the spouse to walk along and give each tree a small drink as you creep along in 1st gear. We did it with 3-3 Norway Spruce and 3-3 Northern Cedar and I don't think we lost any. The buckets are for the bigger trees or things we transplant.
2012 Kenworth T800 T/A Wet Kit Sleeper Cab Truck Tractor (A55973)
2012 Kenworth T800...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
2013 FORD F-350 XL SUPER DUTY- FLAT BED (A58214)
2013 FORD F-350 XL...
2008 International 7500 T/A Altec A77T 76ft. Bucket Truck (A55973)
2008 International...
NEW Long Forks (A59000)
NEW Long Forks...
16 BLADE DISC HARROW (A52708)
16 BLADE DISC...
