How Hot is OK
   / How Hot is OK #1
CharlieTn
Bronze Member
Cocke Cty Tn
Jinma 284
How hot should the case be on a Jinma 284. I was working with the tractor 95 degree day and the heat coming off the tractor and hydraulic lines was incredible. The gauges said it was running in the acceptable range.
Is this normal? The tractor has 30 hours.
   / How Hot is OK #2
</font><font color="blue" class="small">( How hot should the case be on a Jinma 284. )</font>
Define case please.
And it's normal for the rigid hydraulic lines to be hot. Since it's not equipped with hydraulic oil cooler, those exposed lines double as heat exchangers too
//greg//
2022 Toro Workman 07921 Electric Utility Cart (A51694)
2022 Toro Workman...
Set of Ag R4 Wheels and Tires (A53472)
Set of Ag R4...
New/Unused 72in Quick Attach Mower King Hydraulic Brush Cutter (A51573)
New/Unused 72in...
HOMEMADE 4' X 12' SINGLE AXLE TRAILER (A51248)
HOMEMADE 4' X 12'...
2006 TerraGator 8104 (A53472)
2006 TerraGator...
UNUSED CFG INDUSTRIAL MX12RX EXCAVATOR (A51247)
UNUSED CFG...
